2013 gas filler issues - Ford Truck Enthusiasts Forums
2011 & Newer Explorer Discuss the all new redesigned Ford Explorer
Old 11-13-2017, 08:34 PM
Maltman's Avatar
Maltman Maltman is offline
Maltman has a great reputation on FTE.Maltman has a great reputation on FTE.Maltman has a great reputation on FTE.Maltman has a great reputation on FTE.
Hey all, wife's Explorer having issues while filling with gas. She has noticed, not every time, that when filling or putting $20 in that gas will leak from tank/filler area. She explains "gas pouring from under vehicle" Never happened while I have put gas in. Any ideas?
Old 11-14-2017, 01:54 PM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
Something to look at.......if the vapor pump nozzle seal (cone) is not sealing correctly, gas can dribble into the vehicle fill/gas cap hole/area...there is a drain in their mostly for water.......
Old 11-19-2017, 03:30 PM
PupnDuck PupnDuck is offline
PupnDuck has a good reputation on FTE.PupnDuck has a good reputation on FTE.PupnDuck has a good reputation on FTE.
California still uses vapor recovery nozzles on their pumps? All the east coast states quit using them years ago since they don't work with most of the cap-less filler necks.
Old 11-19-2017, 03:32 PM
Maltman's Avatar
Quote:
Yes, we still have them. Except diesel. That makes some sense since gas spills irregularly....
Fuel tank flapper in tank filler tube 2005 Escape oubesto Escape & Escape Hybrid 2 08-19-2016 12:24 PM
Gas fill headache bigfoot22 1973 - 1979 F-100 & Larger F-Series Trucks 16 06-08-2016 10:52 AM
Fuel Filler Pipe Problem LARIAT 85 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 21 04-07-2016 03:00 PM
How hard is it to drop gas tank ugh3012 1999 to 2016 Super Duty 7 02-06-2016 06:35 PM
Trouble filling gas tank 2009 SD 5.4 dudewayne 1999 to 2016 Super Duty 14 11-24-2015 08:36 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
