c-6 kick down and throttle cable with taller intake
Old 07-22-2015, 06:14 PM
winginit's Avatar
winginit
winginit is offline
HI, i am trying to get this 460 back together . I put on a 801 weiand manifolld.
i need to exstend the kickdown a few inches i have 2 should i cut a piece and weld in? what do people do ?
and you can see the angle of the throttle cable to the carb.. is it ok like this? what is the fix ? thanks
Old 07-22-2015, 07:42 PM
fuzzybob's Avatar
fuzzybob
fuzzybob is offline
Holley makes a bolt on one I used on mine but it may not be long enough for your taller mani. You may just have to fab something.
Old 07-22-2015, 08:32 PM
Cranky78 f150's Avatar
Cranky78 f150
Cranky78 f150 is offline
Hello. I cut my kick down tube and found 4 inch metal tube that fit tight inside kick down tube and adjusted the length I needed and welded it together and it is hardly noticeable and works fine. And it retained the factory clips on both ends. You may have to take some of the arch out of the kick down tube to get proper angle but it is very minor.
Hope this helps
Old 07-22-2015, 08:34 PM
winginit's Avatar
winginit
winginit is offline
Hope this helps
Great, that's what I will do, thanks
hharris8
08-08-2016 08:06 PM
tawells01
1999 to 2016 Super Duty
12-04-2012 09:48 PM
1972fordf-100
07-07-2010 04:21 PM
JB88BII
07-24-2008 05:16 PM
2jhanna
04-30-2008 10:10 PM
Quick Reply: c-6 kick down and throttle cable with taller intake
