towing pickups
MY tow vehicle has
engine - 460
gear ratio - 4:10
Transmission - C-6
Tires - Dually - 235/85/R16
RPM - 2500 @ 55mph
Alterations :
1) straight up timing set
2) recurved DuraSpark II .. Running 36 * total timing ..
3) adjustable vacuum advance
4) 1" phenolic carb spacer with heat shield
5) Trans cooler with a trans temp gauge to keep an eye on temps
6) Oil cooler
7) high flow water pump
8) Clutch fan
9) 3g alternator
10) Saginaw power steering pump with a fluid cooler
11) Single 3" exhaust from the Y back with a flowmaster 80 series muffler
Considering :
1) Built AOD transmission
2) Headers and dual exhausts with crossover
3) maybe 3:73 gears
It will haul all day long and won't miss a beat .. But oil stock prices rise as I press the gas peddle
engine - 460
gear ratio - 4:10
Transmission - C-6
RPM - 2500 @ 55mph
Alterations :
6) Oil cooler
8) Clutch fan
9) 3g alternator
Considering :
3) maybe 3:73 gears
MY tow vehicle has
engine - 460
gear ratio - 4:10
Transmission - C-6
RPM - 2500 @ 55mph
Alterations :
6) Oil cooler
8) Clutch fan
9) 3g alternator
Considering :
3) maybe 3:73 gears
engine - 460
gear ratio - 4:10
Transmission - C-6
RPM - 2500 @ 55mph
Alterations :
6) Oil cooler
8) Clutch fan
9) 3g alternator
Considering :
3) maybe 3:73 gears
redroad it sounds like you have your truck dialed in really well.
I am looking for headers for my truck. what brand are you running?
your combination
I have a 79 F350 Crew Cab DRW,460 ,4spd x 4 speed aux trans,(lowest gear is 13.5:1 to highest gear is 0.86 od)4.10 dana 70.Tires are 8 ply 215 85 16 and 70mph is around 2650rpm
I'm pulling a 44ft gooseneck race trailer.
Chris
Got the super cab in trade for putting the motor in the p.o. other super cab, this one has a c6 for now, xlt lariat with full racetrack trim, future plans for now, 86 460 and 95 zf5 with the np 205, running 255/85 16 bfg tires, Custom built flatbed, air bags on rear, 1 inch front add a leaf 3:54 gears, figured this would be alright for now but I eventually want to put a 93-97 7.3 diesel in
elb
05-03-2005 09:56 AM
