1 vs 2 piece drive shaft
Old 06-25-2015, 03:27 PM
Tugly's Avatar
Tugly
Tugly is offline
Stinky is a 2000 4x4 EC LB with 2 pieces, to add to the discussion.
Old 06-25-2015, 04:36 PM
Sous's Avatar
Sous
Sous is online now
Received 4,464 Likes on 2,853 Posts
Currently seems like 2WD from 2000-2003 and long beds have a 2 piece shaft and possibly the 4x4 short beds have a 1 piece from the factory. Waiting for others to chime in before we can get a solid answer on this.
Thanks for those who have participated.
Old 06-25-2015, 05:25 PM
greg_8507's Avatar
greg_8507
greg_8507 is offline
Mine is a 4x4, Crew cab, Short bed with a 2 piece shaft. Might be because it's a crew cab. The distance between the transfer case and yoke is so short as it is I can't imagine a need for a two piece shaft if I had a shorter cab.
Old 06-26-2015, 09:27 PM
SRBF150's Avatar
SRBF150
SRBF150 is offline
Speaking with a driveline shop, their view was a single shaft is for single cab trucks only FWIW.
Old 06-27-2015, 06:16 AM
Walleye Hunter's Avatar
Walleye Hunter
Walleye Hunter is offline
Would extended cab/short bed have the same wheel base as single cab long bed?
Old 06-27-2015, 07:07 AM
Sous's Avatar
Sous
Sous is online now
I would bet it is pretty close, but would have to look into it.
Old 06-27-2015, 08:10 AM
Firefighter 1406's Avatar
Firefighter 1406
Firefighter 1406 is offline
Originally Posted by Sous
So it is safe to say that my truck came off the factory line with a 2 piece drive shaft but somewhere during its nearly 16 year life that was replaced for a 1 piece drive shaft?
My 99 Ext cab short bed 4x4 also has a one piece shaft. Just got it back two days ago from getting rebuilt for the second time.
Old 06-27-2015, 08:19 AM
Tugly's Avatar
Tugly
Tugly is offline
I almost called you yesterday, to see what's new. My drive was through some bad cell service, though.
So your single driveshaft has been repaired more than once? If so, was all the damage done before you reprogrammed back to stock? Have you chipped back up yet?
Old 06-27-2015, 08:39 AM
Firefighter 1406
I have almost called you as well
Ya. Had it done in 2011 and again just this past week. Did my front driveshaft in Jan of this year as well. I don't think the chip he anything to do with the damage. I might be wrong though. Truck is still stock right now. I really need to do some work to the ol girl but the money isn't available right now. I am guessing the driveshaft problems are pulling a trailer and snowplowing related. The driveshaft itself it okay but the joints are always bad it seems. I normally got grease able joints because I thought they would last longer. But the guy at the driveline shop (which I trust) said that the greaseable joints are not built to as tight of tolerances as the non-greaseable ones. So he recommended the non greaseable. So that's the route I went with all new spicer everything. He said it should last 100,000 miles at least. So we will see.
Old 06-28-2015, 08:49 AM
Tugly's Avatar
Tugly
Tugly is offline
All the experts I talked to agree with your guy - no zirks allowed.
Old 06-28-2015, 03:14 PM
ToMang07's Avatar
ToMang07
ToMang07 is online now
I had my carrier bearing grenade on me a couple days ago, it was replaced by my mechanic last spring.
I'm done with 2-piecs shafts, seems the only benefit is "less vibration" but that doesn't seem to be the case with me. Sick of dealing with this crap.
I'm going 1-piece, ordering Monday from one of 2 shops after I get the old shaft off and get some measurements.
Old 06-28-2015, 04:25 PM
Walleye Hunter
I will remember that no zirks part.
My two cents on the two piece vs one. I like simplicity. I have never had drive shaft troubles but I am not hard on my equipment. But I have always felt that the u-joints and the yokes were the weak links in the chain there. One piece drive shaft has two yokes and two u-joints. Two piece has four yokes, three u-joints and a carrier bearing. To me that just sounds like trouble waiting to happen.
rwrogers
03-08-2021 07:47 PM
IBleedOvalBlue
1999 to 2016 Super Duty
06-11-2011 12:31 AM
muddman77
01-17-2011 06:26 AM
twotonestepside
06-21-2008 01:28 PM
Quick Reply: 1 vs 2 piece drive shaft
