Why double drive shaft?
Old Mar 14, 2014 | 06:36 PM
rwrogers's Avatar
rwrogers
Just curious as to why the 66 f100 has a double drive shaft, the total length is only 6', is that too long for a single? Can you put a single in? If so is there any advantage / disadvantage?
I'm just thinking with modern drive shafts, to have a single made up, it would eliminate the center bearing / u-joint.
Old Mar 14, 2014 | 07:14 PM
norfolknova's Avatar
norfolknova
The longer the drive shaft the more likely it is to woble, or not spin true at higher RPM. Once that starts to happen they can bend and break, it is hard on the U-joints. I am sure you could use a newer Aluminum drive shaft if you really want a 1 piece drive shaft. I hae never seen anything in hard writing about the max lenght of a 1 piece drive shaft. I have seen Chevy trucks with extended cab and long bed with a 1 piece aluminum drive shaft
Matt
Old Mar 14, 2014 | 07:49 PM
norfolknova
Here is a chart on the Dana website that lists their maximum length drive shaft for the different drive shaft diameters. For instance for a 4" diameter driveshaft has a recommended max length of 70" and a 5" diameter driveshaft has a recommended max length of 80"
http://www2.dana.com/pdf/DSAG-0200.pdf
See page 12 of the PDF for the chart
matt
Old Mar 14, 2014 | 10:54 PM
66f-100's Avatar
66f-100
I had a one piece drive shaft made when I did my C6 conversion. No vibes or problems at all (even when I took it up to 100 mph).
Old Mar 15, 2014 | 12:21 AM
OrangeBeast's Avatar
OrangeBeast
Here is my experience with a 6' long aluminum shaft...
https://www.ford-trucks.com/forums/1...l#post13282889
https://www.ford-trucks.com/forums/1...l#post13283337
Not that there is anything wrong with them per se, but they can break.
Old Mar 15, 2014 | 01:51 AM
The Masked Rider's Avatar
The Masked Rider
Don't be afraid of Aluminum drive lines. Simply have one ""made that fits your application."" Check out the drive line business below. There might be one near you like this place. There is a bunch of information at this web link. Look around the web site.
http://www.driveshaftshop.com/
Old Mar 6, 2021 | 07:44 AM
vze2c2gb's Avatar
vze2c2gb
Sorry wrong thread
Old Mar 8, 2021 | 07:47 PM
tomrooster-1's Avatar
tomrooster-1
I have a aluminum one on my 66 f100 long bed. It came off a newer Ford but I don't know what. It came as a package deal . I'm using a aluminum 4 speed trans with O/D that came off a 80s something f100. Tom
Ikestang
Oct 22, 2018 06:08 PM
gpbullock
Jul 11, 2009 01:12 PM
oldcoupe42
Mar 6, 2004 07:04 PM
F100DREAM
Sep 22, 2003 06:28 PM
abe1217
Oct 12, 2002 11:07 PM
