part needed
Old Jun 26, 2015 | 04:42 PM
tjc transport's Avatar
tjc transport
i ain't rite
part needed
hey guys, i need an ABS module for my 02 F-250 diesel. anyone have a spare laying around they don't need?
Old Jun 27, 2015 | 08:58 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Did you ever check the wires going to the VSS? If I remember correctly you were having speedometer issues also. Ever since I read back in 05 from kwikkordead that an ABS module that is gone bad will never have other issues. If you have other issues it is the VSS or the wires to VSS. It has held true up to this point!
Just a thought!
https://www.ford-trucks.com/forums/3...bs-module.html
Old Jun 27, 2015 | 11:52 AM
tjc transport
i ain't rite
VSS is new. the ABS module is bad and not communicating with the trucks PCM.
Old Jun 27, 2015 | 01:10 PM
Whitey Ford
Ok, without the ABS module sending the time/speed/distance to PCM nothing using that information will work right including cruise control.
Old Jun 27, 2015 | 02:21 PM
tjc transport
i ain't rite
correct. including the brakes. if you apply them gently they work . if you need to stand on them they freewheel.
i have 2 spare units from gas trucks with vacuum brakes, but they are completely different from what the diesel hydroboost system uses.
Old Jun 28, 2015 | 01:51 PM
tjc transport
i ain't rite
arghhhh!!!!
this truck is really starting to get on my nerves.
i had to move it to fix a flat on a car and when i parked it on a driver side downhill slant, the ABS light went out.
what the heck? so i popped the hood and i can wiggle the plug on the module.
either the screw on the plug is loose or bad, the nut on the module is bad, or the plug into the module is bad.
so more diagnosis is needed. for now it is working with a small piece of wood wedging the plug into the module.
Old Jun 28, 2015 | 03:10 PM
ToMang07's Avatar
ToMang07
Not sure if you're on PSA, but someone posted one for sale (in a bunch of parts) in the classifieds a couple days ago.
Old Jun 28, 2015 | 05:28 PM
tjc transport
i ain't rite
nope, too many know it alls on that site for my tastes.
Old Jun 28, 2015 | 06:45 PM
ToMang07's Avatar
ToMang07
Lots of 7.3 parts must go all prices are obo - PowerStrokeArmy
wiredgeorge
May 19, 2019 06:47 PM
Wbrann51
Dec 15, 2018 06:18 PM
george14094
Jan 17, 2013 11:13 PM
propoutfitters
May 22, 2005 02:53 PM
