Cat delete questions
Old 06-08-2015, 07:44 PM
Magnolia Tom's Avatar
Magnolia Tom
Magnolia Tom is offline
Have an 06 F350 and am thinking of deleting the cat. Two questions:
How much does it help lower (if any) EGTs if I keep the stock exhaust system?
Will it make the truck louder? I ask that because my 05 had a cat delete and it was noticeably louder at both idle and acceleration than my 06 and my wife's 04 Excursion. I kinda like the smooth quiet ride 😎
Thanks for the input
Old 06-08-2015, 08:39 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
I wouldn't bother buying a cat delete pipe. Just go with a full turbo back kit.
Old 06-08-2015, 08:41 PM
Magnolia Tom
I was just going to get the muffler shop to cut out the cat and replace it with a piece of pipe. $60 bucks to do it
Old 06-08-2015, 08:43 PM
MisterCMK's Avatar
MisterCMK
The factory down pipe and exhaust is going to be restrictive as well. You can find a full turbo back for 300 or so.
Old 06-08-2015, 08:51 PM
firedaniel's Avatar
firedaniel
firedaniel is offline
I pulled mine out and used a drill bit to drill it out then used a rod to beat the rest of it out. My delete was free. slightly louder. I have no idea egt as I dont have a gauge but my cat as blocked so it ran much better.
Old 06-08-2015, 08:52 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
You can get a cat delete pipe for about that same price.
Sean
Old 06-08-2015, 09:02 PM
Rellick's Avatar
Rellick
Rellick is offline
I wouldn't think there'd be any difference between an 05 and an 06 as far as sound goes. Unless of 'course your '05 had an AM muffler too...
Old 06-08-2015, 09:39 PM
Magnolia Tom
Nope. Stock muffler on the 05.
Old 06-08-2015, 10:28 PM
Tennesseepowerstroke's Avatar
Tennesseepowerstroke is offline
Of course I still have mine, but if I had it deleted it would not be noticebly louder and would only be around $40.
Old 06-09-2015, 07:14 AM
Magnolia Tom
Any effect on EGTs??
Old 06-09-2015, 08:28 AM
MisterCMK's Avatar
MisterCMK
I couldn't give you any firm numbers but I do remember when I deleted the cat with the rest of the stock exhaust in place the temps dropped a little.
Old 06-09-2015, 11:14 AM
Magnolia Tom
When you say a little, is that like 20-30 degrees or like 100 degrees?
Old 06-09-2015, 03:38 PM
brandonrr's Avatar
brandonrr
brandonrr is offline
I've been debating between gutting the cat in my truck or just getting a cat delete pipe. With the delete pipe, I would have to swap it back and forth each year for emissions, but at the same time, I realize the OEM cat is around $2800 from Ford and if I end up moving to California, they only allow OEM cats. My fear if I gut the cat is failing emissions if I move to Cali. It would, however, make emissions in just about every other state more convenient.
I would also like to know the EGT difference after deleting just the cat.
Old 06-09-2015, 03:57 PM
HT32BSX115's Avatar
HT32BSX115
HT32BSX115 is offline
Um........Why would anyone in their right mind move to California?
Old 06-09-2015, 04:09 PM
brandonrr's Avatar
brandonrr
strictly for work and no other reason. If I did move back there, it would not be by choice lol
Quick Reply: Cat delete questions
