Third brake light options???
lets see your third brake light ideas....
I am thinking about what I like better.
adding something to the cab, or something to the bed....
What did you do???
this guy used a weld in kit from this company.Hitech Led Products
I think the light on the tail gate roll is neat.
And how can you go wrong with bed roll lights.
What did you do???
I have a '69 F100 Ranger and realize it's very different from a '48 to '56 model but, I converted my factory cargo light to double as a high-mount 3rd brake light using an 1157 dual element socket and a white/red switchback LED. I wired the 3rd brake light off the switched side of the brake pedal switch. While my truck is different than the ones in this forum's section, someone might be able to apply the basic principles I used in my conversion.
This is how I did the modification on my truck.
See posts #182 & 185.
https://www.ford-trucks.com/forums/1...l#post14947258
See post 321 & 324.
https://www.ford-trucks.com/forums/1...l#post15047943
See post 321 & 324.
Most of us are running around with a combined s/t/t lamp. With That said you could certainly run a new wire to the brake light switch just for the CHMSL.
Or you could wire in a tail light converter that will separate the s/t/t functions into stop/tail and turn.
My only concern would be anything too long for the bed sitting on top of the tailgate possibly cracking this...but I use my truck as a truck!
LCA078
17
10-23-2015 11:43 AM
Quiff_boy_Elvis
09-11-2009 02:36 AM
