Help decoding my 351w
The block casting number is, d2ae-6015-ba16, and above that was a little stamp that had 2523, my intake has a d3OE-9425-ba just curiosity as to the difference in the OE AND AE, I know the d3/d2 is 73 and 72, I'd also like to find casting numbers on the heads but can't seam to find them anywhere.
A= full size Ford car.
O=Fairlane and Torino.
But this is USUALLY which vehicle the part was originally designed for. Not necessarily which vehicle it was installed on.
The head casting numbers will be found on the under side of the heads --between the pushrod holes, on the underside of one of the intake ports.
Browse - Casting Numbers .info: engine blocks, heads, and more
The D9AE casting you gave goes back to a '79 model Ford passenger car engine. The basic part number for all Ford engine blocks is 6015 regardless of engine type, instead of the 1650 you listed.
Off the top of my head, I don't think the truck 351W went to a roller cam until around '94 (possibly late '93) -- you would be looking for an F4TE block. '87 would definitely have a standard hydraulic cam and not a roller.
Flat 'n Fat
07-24-2022 04:50 PM
Scoop531
12-04-2013 11:39 AM
92mustangLX
06-13-2008 04:34 PM
BroncoRoadKill
02-25-2007 01:39 PM
rangersvt04
09-27-2005 11:10 PM
