Gearing help
Old Nov 11, 2015 | 06:56 PM
sand1's Avatar
sand1
Gearing help
If I have 410s with a 3 spd auto 33 inch tires will the truck FEEL like it needs to shift again in 3rd gear
Old Nov 11, 2015 | 06:57 PM
sand1's Avatar
sand1
If so what gearing do I need to switch to
Old Nov 11, 2015 | 08:45 PM
HIO Silver's Avatar
HIO Silver
But what is your typical cruising speed?
2WD or 4WD???
For all around performance on a 4WD, 3.70 or 3.50 would be decent with 33s. 4.10s would be good with 35s.
Old Nov 11, 2015 | 08:46 PM
351Cleveland C4's Avatar
351Cleveland C4
I agree with HIO. Even a 3.25 if you do a lot of highway cruising.
Old Nov 11, 2015 | 09:44 PM
sand1's Avatar
sand1
4wd. speed don't exceed60mph
Old Nov 11, 2015 | 09:46 PM
sand1's Avatar
sand1
I want it to be smooth will it wind out with the 410s
Old Nov 11, 2015 | 09:59 PM
HIO Silver's Avatar
HIO Silver
My recommendations are previously stated, above.
I have 4.10s in my F250 (2WD) and I'd like to drop it down to 3.73s... Or go nuts and slap on an Autofab 3-inch lift and 35s.
Old Nov 12, 2015 | 11:14 AM
TeachNlive4ever's Avatar
TeachNlive4ever
GO NUTS HIO GO NUTS!!!
Old Nov 12, 2015 | 12:41 PM
HIO Silver's Avatar
HIO Silver
LOL.
I'm looking for one of these in anticipation of a midlife crisis and have about six months to find one...
Old Nov 12, 2015 | 03:46 PM
wrhinehart's Avatar
wrhinehart
This 465 CID beast didn't even blink when I changed the ratio. I was running 4.10's. I opted for 3.73's
Went from 9 MPG on the road almost 12.
Was taching 3500 at 65, now taching 3500 and 75.
It makes for a more modern truck.
Remember that back then the Maximum Speed limit was 55.
"I can't drive 55."
Who sang that.? (Don't google it.)
Old Nov 12, 2015 | 04:41 PM
ultraranger's Avatar
ultraranger
Originally Posted by wrhinehart
This 465 CID beast didn't even blink when changed the ratio. I was running 4.10's. I opted for 3.73's
"I can't drive 55."
The song was written by the 'Red Rocker,' Sammy Hagar on the VOA (Voice of America) album.
Our Bumpsides pre-dated the national speed limit reduction to 55 MPH. That was passed by Nixon in 1974. As a kid, I remember when the highway speed limit in Arkansas (pre-NMSL speed limit) was 75 MPH.
Old Nov 12, 2015 | 04:59 PM
wrhinehart's Avatar
wrhinehart
We have a winner!
Old Nov 12, 2015 | 05:07 PM
itsabullitt's Avatar
itsabullitt
I have 4.11's in my 4X4 with 33" tires. I have an Overdrive trans, but can run 60-65 in 3rd and only turn about 2500 rpm. Kick it up into OD and rpms drop to about 1700.
Edit, You didn't say what engine you have. I've got a small block with an aftermarket cam and intake that performs best around 2500 rpm and up. For a stock application in say a 390 or 360, you may want a steeper gear like a 3.73 or so to keep you in your peak torque range when at highway speeds. I use mine as more of a play toy and around town driver and hardly ever drive more than 10-15 minutes at highway speeds at a time. If you do the same, then I say 4.11's should be just fine.
Old Nov 12, 2015 | 05:32 PM
Alex from GA's Avatar
Alex from GA
Go here, plug in your data and see your RPM. Engine RPM Calculator
Old Nov 12, 2015 | 07:02 PM
351Cleveland C4
"I can't drive 55."
Gee whiz, that's still a low gear. I've got a 2.75 final ratio with 31s and tach about 2400 at 75mph.
jcb4jcb
Texas Chapter
Feb 2, 2015 01:25 AM
Tex_Hoss
2009 - 2014 F150
22
Aug 17, 2010 11:45 PM
bartamos
Offroad & 4x4
13
Mar 5, 2009 05:38 PM
tholt34
13
Jul 24, 2008 09:16 PM
