Hi All
Any one have a diagram or know which wire to tap so I can trigger/run my aux back up light? I tried tapping the existing wire behind the tail light and it didn't work, made the truck do funny stuff like killing the ignition. I had read on here on white knights web site that on the newer trucks you cannot use the back up circuit from the seven pin so I didn't try that. I don't have up-fitters and really didn't want to run a wire to the front but will if that is the best solution.
Thanks in advance.
Thanks guys
I will try the center wire this weekend when i can get back to it.
Good luck. I simply followed up the wire from the trailer plug on my truck and pulled back the wire loom. I cut the wire, stripped both ends, and soldered in my wire so all had a nice solid soldered connection. I then wrapped everything up in harness tape.
If you are planning to do a bunch of reverse lights, you should run a wire from the battery to a relay then have the relay connected to the backup wire but if you are just doing a single LED light or something like that, this should work fine.
I am just going to hook up a single "fog light" that I have had laying around to get some extra light. I should of ordered a back up cam but live and learn.
