Reverse Light Wire Color
Old Apr 19, 2013 | 05:50 PM
cschannuth's Avatar
cschannuth
I've searched all over and can't seem to find the answer. When I pull the tail light out of my 12 F150 there is a blue/wht wire and a black wire going to the back up light. I assume the blue wire is the positive and black is the ground. Is that correct? I also posted this in the F150 section. Thanks.
Old Apr 19, 2013 | 07:02 PM
johnday's Avatar
johnday
I'm pretty certain that's the way it is. If you have any doubt, pull the bulb out, put car in reverse by someone you trust, and take a multimetre and find which side of the socket has power, then look at the wire feeding that side of the plug.
Most times, black is your ground, but, I've seen white, and brown, and even orange.
Old Apr 19, 2013 | 09:30 PM
cschannuth's Avatar
cschannuth
Blue/wht is power and black is ground. I hooked up my back up lights and they work great.
Old Apr 20, 2013 | 06:11 AM
johnday's Avatar
johnday
And there ya have it!! What type of backup lights did you install? I did some on my little Ranger, but am not overly thrilled with them, and am open to suggestions. I'm heading downstate in a bit to see my wife, and plan on stopping at "Herby Fright", ah, Harbor Freight, and see what they might have for cheap.
Old Apr 20, 2013 | 07:53 AM
Franklin2's Avatar
Franklin2
Be careful. The factory switch can only handle so much load.
Old Apr 20, 2013 | 07:36 PM
johnday's Avatar
johnday
Very true. I wired them thru a relay with the backup light wire as the trigger.
Old Oct 18, 2013 | 10:07 AM
dkd114's Avatar
dkd114
I just got my VLEDS LED plate frame and wired it to the wires supplying my reverse light on the driver's side. I have a strange problem...
LED and reverse lights work fine when truck is not running (key in accessory mode and vehicle in reverse)
When the truck is running, when I put it in reverse, it seems as though a circuit "trips" and both the LED frame AND both reverse lights go out. If I turn truck off and back on and disconnect LED frame, both reverse lights work again.
It is a good connection as I cut the wires and used actual wire nuts. Would you happen to have any suggestions? It is a 2013 F150.
Thanks!!!
Dan
Old Oct 18, 2013 | 09:06 PM
Franklin2's Avatar
Franklin2
How many wires did you splice into and run to the new frame? 2? I wonder what would happen if you took one of the frame wires off(the one you think is negative) and touched it to a good ground, and left the other one hooked up. The only think I can think of, is if you did splice into a wire for the ground, you hooked into something else that is not really a ground.
Old Jan 9, 2015 | 05:15 PM
cschannuth's Avatar
cschannuth
VLEDs. Work great. Very bright.
Old Mar 13, 2019 | 01:48 AM
mikeweber's Avatar
mikeweber
Any Luck>
Thanks!!!
Dan
I know this is an older post but I had the exact same thing happen to me. Spliced LEDs into the reverse wire all lights went out. I pulled the factory bulbs out and the LEDs worked when i was in reverse. They worked for about a month and all of the sudden they stopped working and I have no power to any reverse wires. Any thoughts?
Old Mar 24, 2020 | 04:46 PM
James P Dodson's Avatar
James P Dodson
It depends on your factory setup.
i recently added a 5 pole flat adapter to my existing 4 pole flat connection on my 2018 F150 XLT.
My 2018 F150 reverse wire color was green with brown stripe.
I needed the 4 pole flat to 5 pole flat adapter to pull a boat with a surge brake lockout. Etrailer.com sold me the adapter.
cschannuth
2009 - 2014 F150
Aug 10, 2020 07:02 AM
Mrfun2fly
2015 - 2020 F150
Mar 20, 2018 02:15 PM
oceantrav
Jan 11, 2017 04:43 PM
Jax Rhapsody
1978 - 1996 Big Bronco
Mar 24, 2011 06:55 PM
vmark
May 3, 2009 01:26 AM
