What happened to my steering stabilizer?
I have a 2000 F250 Lariet crew cab with 8ft bed and 4X4. I have a little play in the steering wheel so after reading on here about people changing their steering stabilizer, I thought I would check mine. It appears I don't have one. Kind of got the impression that all F250 had them. What would it take to install one? Would I have to buy the factory brackets first or are their kits that have brackets with them. Rather new to forum and any help would be appreciated.
Quoting my old post from install. I did not have a stabilizer to replace or any hardware. Primarily from Ford you will need the U bolts and the black bracket, all the nuts and bolt can be purchase locally at a Hardware store. Also note I put everything needed in the quoted post.
Link to same thread:
https://www.ford-trucks.com/forums/1...er-w-pics.html
Thanks OP for the pictures. I used them and definitely helped.
So installed my stabilizer Wednesday. What was a 30 minute job lasted over four hours and 3 parts store runs. I ordered all Ford hardware back in January and my stabilizer in March. All OEM pieces were in hand for a while. The stabilizer showed up a couple weeks ago in April.
First was to get a bolt and washers that match the nut supplied. M14x1.5x70mm. Return home and the bolt is to large for the hole on the axle.
Second run is to exchange the bolt and get M12x1.5 hardware as the hole is to small. The Bilstein bushing collar is less than 12mm from my handy Digital Caliper, similar to the bracket holes. Returned with Bolt, 2 washers and a locknut.
Return home and realize the nuts supplied with the U bolts appear small. Attempt to thread them together and get no where. Google the U bolt hardware part number and come up with M10x1.5.
This time to home depot as the closer store Mclendon was closed. Locate the appropriate nuts and washers return to install everything. Completed install and torqued in less than 30 minutes.
While underneath I also hit the lower ball joints, center link and drag link zerk fittings with grease.
I will say if you don't have a steering stabilizer it is a noticeable difference compared to over 10k miles by me daily driving on the wonderful Seattle roads.
On to the pictures:
What I thought was complete
Installed
On to the pictures:
Installed
If it is the loose steering you are concerned about, I would start by looking for worn ball joints or loose tie rod ends. These are common wear and tear items on these trucks. I wouldn't spend your money on a stabilizer kit just yet. It won't do you much good if you have other worn out front end parts.
I will go with the above advice. My 2004 F250 has a steering damper, but there is more play in it than my 2001 F250 with no steering damper. When I replaced the ball joints on my 2004 F250, the little play went away.
joelgator
02-27-2005 10:22 PM
