No brakes!!!!!!
No brakes!!!!!!
As my user name implies, I have a 1950 f4 I am tinkering with. So far I have: rebuilt carb, replaced all rubber hoses/lines, replaced coil, and finally replaced the dreaded WM wheels with solid 19.5's(only scored 4 but they have brand new tires on them!). With all that said, the brake master cylinder has bit the bullet & Is leaking like a screen door on a submarine. Rebuild or replace? Anyone done a rebuild, how difficult & how many adult beverages required?
Thanks.
Thanks.
Rebuild kits are available for the old M/C's. But a lot of the guys lean toward a dual reservoir M/C for safety reasons. If you lose brakes on one axle you still have the other to stop with. Not sure where they source these M/C's but I'm sure someone will pop in who's more experienced on such things. Also welcome to FTE! Glad to see another F4 being saved.
There are a few threads on here that members put the booster MC on under the cab in the original place. Just know your brake size and make sure you get big enough for your shoes and fluid needs. I have a F6 and had to go with a chevy unit that was 1.25 bore to deliver enough fluid for my shoes. Remember you only have to deliver your bore to 2 wheels.
50model-F4, Welcome to FTE! Glad to see another F4! What does your truck have for a bed? We do need to see pics! You can get a master cylinder from Rock Auto. I would recommend that if you are staying with the original type master cylinder, that you replace the master cylinder instead of trying to rebuild the one you have. Unless your original is already sleeved with brass or stainless steel, it will probably be too deeply pitted inside to hone and accept a new kit.
on
Here is how to post pic's on FTE
https://www.ford-trucks.com/forums/1...ure-guide.html
Here is one way by "Axracer"
Do you have digital pix of your truck from digital camera or phone on your computer? If so it is easy to add them to a post (assuming the file is not too large). Find the pic on your computer and leave it open while you come here in another window. Compose a post, click where you want the pic to appear in the post. Click on the picture icon at the top of the posting box (looks like a postcard with mountains and sun) A dialog box will open asking if you want to drag a pic onto the box or browse your computer to find it. If you have the pic open, go there, right click anywhere on the pic and chose copy from the menu. Come back to your post and right click on the box. Select paste from the menu. Your picture should appear (it may take a few seconds to load) in the box. Now left click on the insert button.
If the stars all aligned your picture should now be in your post window. Select post to have it appear on the forum or repeat to add more pix. Some cameras make huge files these days that are larger than the forum limits. You may need to resize or resample the picture and save the smaller file version with whatever picture editing software came with your picture taking device before you can post it.
Oh! and welcome to FTE and the old truck madness.
Job Lot Auto is a good source for brand new brake parts for the bigger trucks. A while back they had a package deal consisting of MC, four wheel cylinders and three hoses for $300. It's been I while since I checked with them so I don't know if they still have the parts but when I did check it out the guy there said these are new parts, not rebuilt. I'm just putting this out there for future reference for anyone else looking for these parts are willing to put out the dough.
It's got to be the angle, not sure of dimensions, but it's a small back glass. Also, thanks for posting/relocating my pic, I have still yet to master that........I'll try & post underhood & interior pics asap for any would be buyers.
Thanks
Corey B.
Thanks
Corey B.
Weissfarm
44
04-01-2017 04:52 PM
Njmyers
03-20-2016 11:28 AM
Tyler S
19
11-07-2011 10:31 AM
