i want to put a 429 in my 93 f350
i have a 429 thunderjet engine that is externally balanced will a newer 5 speed trans work and what don i have to change i now that the bolt patttern is the same from a 429 to 460 whatv about the spacing of the flywheel and the space on the starter gear any help would be great thank you
go check these two forums here....i suspect you will get an answer easier on them than here
Includes 93 model trucks
1987 - 1996 F150 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
385 series engines
Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) - Ford Truck Enthusiasts Forums
385 series engines
429thunderjet93f350
03-26-2015 10:46 AM
rdz
02-21-2007 09:47 PM
