Sponsored by: Real Truck
429 swap
Old Mar 24, 2015 | 08:41 PM
429thunderjet93f350's Avatar
429thunderjet93f350
429 swap
Can someone tell me if a zf5 will bolt up to a 429 thunderjet I see they will bolt up to a 460 is there anything I need to change like the flywheel or starter?????????
Old Mar 24, 2015 | 08:47 PM
Just Strokin's Avatar
Just Strokin
The 429 and 460 are basically the same engine externally. The only major difference between 429 and 460 is the stroke of the crankshaft. You will need the correct flywheel for the balancing method used for your crank. Early engines were internally balanced and later model engines were externally balanced. If you have the "hatchet" style front harmonic balancer spacer, it is externally balanced. If it is just a round spacer, then it is internally balanced
Old Mar 27, 2015 | 09:47 PM
Psyclopse's Avatar
Psyclopse
Out of curiosity, what are you swapping this into?
429thunderjet93f350
Mar 26, 2015 10:46 AM
73 Crew
Sep 6, 2013 08:04 PM
Vean555
Jun 27, 2012 12:33 PM
fordsd87
Jul 3, 2009 09:12 AM
rdz
Feb 21, 2007 09:47 PM
