Transfer case Swap ?
I have a 94 F250 4x4 with a 351w the transfer case which is a borg warner 1356 is corroded and leaking and i want to replace it ... I have a borg warner 4407 tcase that came what im assuming was a 460 or 7.3, correct me if im wrong ... My question is is there any way that i could use that transfer case on my truck ... Are the bolt patterns the same and the shaft splines ... Any help is appreciated ... THANKS !!!
Like said above... the 4407 will bolt in place of the 1356.
BUT the rear driveshafts are different
1356 is a slip yoke
4407 is a fixed flange
and YES the shafts are different
Also the front yoke is different between a F250 and F350 so you have to know what it came out of
1356 is a slip yoke
highoctane74
09-10-2016 04:03 AM
Gear619
01-27-2015 12:08 PM
lastchance
07-16-2004 08:45 PM
