transfer case swap
Old Jun 11, 2005 | 08:20 AM
kford96's Avatar
kford96
transfer case swap
was wonderig if anyone has ever used a transfer off a automatic transmission on a standard they are both 1993 ford trucks and look the same I just don't want to buy the transfer and find out the hard way it wont work thanks for any help
Old Jun 11, 2005 | 04:16 PM
SoCalDesertRider's Avatar
SoCalDesertRider
I believe Ford transfer cases use the same input shaft and bolt pattern regardless of the type of trans in front of them, but you should count your shaft splines and measure the mating bolt pattern and compare to the t-case you intend to buy, to be sure.
