DEPO lights - Cracked....2 sets!!
Old 02-17-2015, 09:08 PM
SoCalAngler's Avatar
SoCalAngler
SoCalAngler is offline
I was excited about this mod but not so much now.
I ordered a set on ebay. As I was screwing bulb into oscket, the bulb socket on housing cracked!!!
Returned for a new set. Installed today and bulbs installed OK. Began to adjust pass side and then moved to drivers'side. Made several adjustments and noticed that beam was no longer moving. Checked light housing and guess what.....bulb housng was cracked and bulb fell completely out
of housing!!!!
Now what? Order another set of DEPOs?
Should I get a refund and purchase a different brand? These were made in Taiwan.
Are there any quality sets out there?
Is the Anzo brand pretty much the same quality?
Frustrated to no end
Old 02-17-2015, 10:57 PM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
I've heard Depo was a decent brand, but don't know all that much about them. Depo seems to be one of the preferred replacement brands. I prefer TYC or Eagle Eyes. The worst is Vision.
I used to prefer Ford replacements, but my friend just got a set and within 6 months they had water in them. I think they are not any better than other replacements now. They're probably made in the same place.
Old 02-18-2015, 09:17 AM
SoCalAngler
I have thought about this to be sure that I am not doing something wrong and causing the bulb bases of the housing to crack. I can't think of anything. Any housing that can't withstand a bulb tightened with the supplied plastic nut/bulb holder, is a low quality product. The OEM Ford ones appear to be made of a higher grade of plastic.
NOTE: As I was removing the pass side housing, the base of the bulb holder was also cracked!!! As soon as I unscrewed the bulb holder the bulb socket cracked!
Now what?
Wondering If I should just get a new set of OEMs and be done with this?
NOTE: I did do the wiring mod with relays and heavier gauge wire. Hey, at least that project appeared to work (the lights turned on!!).
Not sure if this mod will help much with OEM lenses?
Will OEM lenses be any better with the mod and Sylvania Ultra halogen bulbs?
Thanks!
Old 02-18-2015, 12:47 PM
SoCalAngler
Thinking about the TYC brand of OE lights. $49.00 each at Oreillys...that's more than the DEPO which were $69.00 a set shipped.
Old 02-18-2015, 03:46 PM
Lightning LA's Avatar
Lightning LA
Lightning LA is offline
I just replaced my old Headlights with a Set of OEM Ford, and before I put them on I'm going to seal them up so I won't have to worry about any moisture issues. I figured they are the best since there OEM Ford, and the ones on my Truck now have lasted good. The only issue is the Yellowing, and a little condensation in them. That's why I'm going to seal the new ones up, so I won't have that issue later on. I found the Headlights on e-Bay, that's the cheapest place I could find the OEM Lights. U-Haul has a Store on e-Bay under the name of U-TECHCENTER, and they sell a lot of Brand New OEM Ford Parts that fit our Year Trucks. And I bought 1 of my Headlights from them that was brand new in the Ford Box, and I got it for about half the price other sellers are asking. So you might check them out if you want to go with OEM Ford...
Old 02-18-2015, 05:37 PM
ncranchero's Avatar
ncranchero
ncranchero is offline
I've never had any issues with Depo lights, used quite a few. I had one new TYC headlight and bought a Depo to make a pair for my Taurus. I couldn't tell them apart. YMMV.
Old 02-18-2015, 08:05 PM
SoCalAngler
Update.....
Returned the 2nd set of DEPOs.
Purchased the OE TYCs from O'Reilly AP. They price matched Pep Boys and got 'em for $27.99 each.
Installed and the fitment is great. Adjusted and all looks great!!
Old 02-18-2015, 08:25 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
interesting.never had problems there.the depo adjusters and mounting hardware is real cheap.i tried to swap over all the oem i could, but haven't run into cracking the cases.......yet lol.
how are the TYC brand in comparison for quality? are they oem style or depo clear style?
Old 02-18-2015, 09:38 PM
SoCalAngler
The TYC are OEM style with lines in lens. The appear to be a little better quality than the DEPOs. As you mentioned, the adjusters are of low quality compared to OEM. New lenses and Sylvania Silverstar Ultra bulbs provides a pretty good driving light for 23 year old technology! I actually like the look of the OEM style as it makes it look its vintage.
Myf350sd
2017+ Super Duty
17
08-19-2019 06:14 PM
crewzer
2017+ Super Duty
59
10-21-2018 01:07 PM
cdmm151
2015 - 2020 F150
25
09-26-2016 07:36 AM
SSSimon
Australia Chapter
22
09-30-2014 05:17 PM
wakesnowb
1997 - 2003 F150
07-20-2003 01:56 PM
Quick Reply: DEPO lights - Cracked....2 sets!!
