Glow Plug Testing Question
Hey yall, I am having some trouble starting my 1999 7.3 when it gets below 25 degrees and need some help figuring it out. My GPR was bad and so I replaced that and it still has a lot of trouble starting. The truck will not crank for awhile and then if i get it to start it will lope for at least 15 to 30 seconds before running at an idle. I checked the olms of the glow plugs and they are all reading 0.0. I read that they are supposed to be between 0.5 and 2.0. Does this mean the glow plugs are bad? I also checked to see if power was coming to the glow plugs when the key is turned and they are receiving about 11 volts. If you have any ideas I would appreciate it. Thanks in advance
Thank yall for the help, you were right about the multimeter. I had it set on autorange. I changed that to the lowest setting and now all the glow plugs are within the 0.6 to 2.1 range. All the glow plugs must be good as well. My batteries are reading 12.3 volts and then when the key is turned the glow plugs are receiving 11.2. I am going to go get my batteries tested tomorrow and see if there are any cells messed up and see what the cold cranking amps are at. And as far as smoke, there is a good bit of white smoke but it aint thick enough where you cant see through it. Any other ideas?
I've been beating this drum lately, and I'm sure a regular or two may find this as a cue to click the next thread. Everything on the whole GP system can check out externally, but that does not automatically mean it will work as designed. The problem is glow plugs lose their oomph over time/cycles, so the final test is to pull one out and apply 12 volts with jumper cables. You can then compare the reaction with videos found on YouTube.
Received 3,113 Likes
on
my 02 just started doing the same thing. of course it is plowing season, and i can't take it apart now so i just plug it into a switched outlet and turn the block heater on 2 hours before i go out.
i will just have to live with it until spring time when i can lay the truck up for a week to change the glow plugs and get the injectors rebuilt.
mozzles
10-22-2012 08:33 PM
