How to stroke a 351W
Hey everyone. My truck has alot of miles on it so I have decided that in the near future im going to pull the motor and rebuild it. I have read that it is worth stroking the 351 so I would like to do so but can not get the right direction on google haha. I have a 1996 F150 ext. Cab with the 5.8. Any and all advice is a great help to me. Btw. This truck will be used as a regular truck. Pulling trailers, hauling things etc. Im not looking for a race truck just want some good ol' truck power.
Plenty of info on google or search function in this forum.
I did a 393" kit because it uses stock 302 pistons, but in the end I don't think there's much cost difference.
I'd say GT40 heads from a pre-97 explorer / mountaineer would be the minimum, however, unless you can get a good deal on cores it might be cheaper to get aftermarket heads. Maybe you can talk the machine shop into exchanging the GT40 heads for your E7's
I'm not an expert on this, but I'd be really surprised if you can run 10:1 compression on regular 87 octane, at least not without retarding the timing an awful lot. You ought to be OK on premium, if the concern is being able to buy gas at a normal station rather than in 55 gallon drums from a distributor. but don't expect to be able to use the cheap stuff.
stock engines are barely over 8:1. makes for a very soft and abysmal throttle pedal. i'll take higher compression all day long, especially in a truck engine that will be used for work, and torque is a must. when setup properly, and accounting for the added cost per gallon, it'll at least break even with an 87 counterpart with the addition of great pedal feel and better overall driving experience.
the only problem with using the 393 is the pistons themselves. the short skirt can promote premature cylinder/skirt wear. I cant attest to it personally, because ive never run a short piston stroker for long periods of time, but its not a coincidence that engines utilizing long strokes across the board also use taller pistons respectively.
I'd get a kit that comes with pistons, with some high flow small"er" port heads, and run 10.5-11:1 compression, and of course an SD friendly cam with 1.7 rockers. intake work and long tubes are a given, I assume. you will not be displeased.
fireman660r
19
02-13-2009 02:16 PM
Redneck1465
01-19-2009 01:03 PM
matt16875
99
12-19-2006 06:55 PM
