fomoco grey goop
Old 11-20-2014, 09:01 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
fomoco grey goop
Kay fellas. The gasket on my manual trans for the inspection plate on the side is leaking. I pulled the cover off and it has a slight bow to the one corner. Will the fomoco goop be okay to use with the atf or should I get the proper seal and straighten or replace the cover.
Old 11-20-2014, 09:23 PM
fordman67's Avatar
fordman67
fordman67 is offline
I would use the grey goop.its like concrete when its cured.
Old 11-20-2014, 09:37 PM
MOOSE_MACHINE
That's what I wanted. A scapegoat lol. Thanks
Old 11-20-2014, 09:57 PM
madpogue's Avatar
madpogue
madpogue is offline
The PTO cover? I would flatten the cover and get a replacement gasket. A LOT less messy than anything in a tube if/when you ever have to remove it again.
Old 11-20-2014, 10:37 PM
stainlessstroker95's Avatar
stainlessstroker95
stainlessstroker95 is offline
When my father in law rebuilt mine, we used the ford goop on a couple of the mateing surfaces.
Old 11-20-2014, 10:51 PM
MOOSE_MACHINE
Hmmm. The goop is easy now. But I know what you mean by later. I'll see if I can get one tomorrow. If not I'll goop it
Old 11-21-2014, 08:28 AM
Thor'sHammer's Avatar
Thor'sHammer
Thor'sHammer is offline
The "goop" is actually this -
http://www.reynoldsam.com/product/metalset-a4/
I've patched bullet holes in Pavehawk helicopters with this stuff. It's good.
Old 11-21-2014, 09:27 AM
MOOSE_MACHINE
Originally Posted by Thor'sHammer
The "goop" is actually this - http://www.reynoldsam.com/product/metalset-a4/ I've patched bullet holes in Pavehawk helicopters with this stuff. It's good.
Yeah I know it's good. But if ever I need to go back into the trans ie rebuild, that crap is a ******* to get off. I'll call when the parts store opens. If the can't get it by the end of the day I'll goop it
Old 11-21-2014, 11:18 AM
madpogue's Avatar
madpogue
madpogue is offline
^^^^^^ +1. Bullet hole repair should be permanent. Seal for a removable part should not. Those PTO covers are a somewhat generic configuration, not just found on the ZF. Might be worth tracing the outside of the cover and the spacing of the bolts, as a way of matching one up.
Old 11-21-2014, 01:47 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Just make a gasket with the cover, gasket material and a small ball peen hammer. DONE!
And you will be able to get it off when needed withOUT destroying it
WilleyJoe.62
19
03-04-2014 07:44 PM
GK4x4
1999 to 2016 Super Duty
07-01-2012 01:06 AM
slow3v
10-06-2011 09:04 PM
Neal 97 250
05-30-2007 09:17 PM
MARC
01-16-2005 03:21 PM
Quick Reply: fomoco grey goop
