Sponsored by: Real Truck
Differential cover
Old Jun 29, 2012 | 09:13 AM
GK4x4's Avatar
GK4x4
Differential cover
I have a 1999 F250 diesel 4x4 with manual tranny. Differential cover is rusting to the point it is paper thin. Any tips or tricks in replacing this 12 bolt hole cover? The shop manual says use sealant as a gasket. They sell cover gaskets. Anybody know if a preformed cover gasket is OK to use?
Old Jun 29, 2012 | 10:47 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Give Clay a call and he can get you what you want/need. Here is what you are looking for. Clay is also a sponsor of FTE.
Riffraff Diesel Performance Parts: - Differential Covers
Old Jun 29, 2012 | 11:13 AM
JIM_C's Avatar
JIM_C
Been reading up on this myself and I think most people use the silicone. Very few problems. Not many problems with the gaskets either but moreso than the silicone.
Old Jun 29, 2012 | 11:47 AM
Kdr358's Avatar
Kdr358
I've used both silicone and the gasket with no difference. My cover is starting to get moist near the bottom I found a used cover on eBay from California ( no rust) for 50.00. I don't really care for the aftermarket look wich is why I went that route. Oh also no matter what you will still have to scrape the goo off from a gasket it silicone
Old Jun 29, 2012 | 12:51 PM
JIM_C's Avatar
JIM_C
Well for pretty much the same money you can get an aluminum finned rear diff cover that Ford puts on the '08+ trucks. It should fit your 2000 if it has the 10.5 rear. I just bought one and will install when I make time for it. Part # is 8C3Z-4033-A
https://www.ford-trucks.com/forums/8...with-pics.html
Old Jun 29, 2012 | 01:09 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Mine look's about like Bill's did in that ^^^ link. I'm going with the factory aluminum one and black RTV, unless you tow boats and are sticking your read diff under the water while it's hot, there's really no need for a drain plug in the cover or a gasket that doesn't need a little cleaning when it comes off.
Old Jun 30, 2012 | 06:58 AM
mck2000's Avatar
mck2000
parts guy ed has them i just got the aluminum fined one 55.00 shipped u need 1 1/4" bolts
Old Jun 30, 2012 | 07:59 AM
kd0axs's Avatar
kd0axs
I would use The Right Stuff instead of regular RTV/silicone. It works much better and it can be used immediately, no waiting for it to cure like regular RTV/silicone.
Old Jun 30, 2012 | 08:35 AM
Pitcrw6's Avatar
Pitcrw6
This stuff works great. 100 times better then RTV IMO.
Old Jun 30, 2012 | 10:21 AM
dkf's Avatar
dkf
Thats what I used on the last 4 diff covers I did. Sets up nice and firm like the OE sealant and no leaks.
Old Jun 30, 2012 | 11:15 PM
99f350sd's Avatar
99f350sd
Only use the right stuff!!!!! What they said! Buy a stock cover sandblast 2 coats of rustbullet and never worry about it..
Dick
Old Jul 1, 2012 | 12:30 AM
95YJman's Avatar
95YJman
The Diff cover did this on my 05 F350's 10.5..I was gonna get a 08+ diff cover at the time but instead went with just a plain old black stock cover. The ford dealer gave me this sealant meant for something on 7.3 diesel. and it sealed it up great! However the motorcraft diff fluid is like 20 bucks a quart..worth it though I guess
Old Jul 1, 2012 | 01:06 AM
kd0axs's Avatar
kd0axs
Not really. Mobil 1 or Amsoil is just as good if not better at half that price. I don't think the Motorcraft stuff has the LS additive in it either, you have to buy that separately. I know Mobil 1 already has it added and I'm pretty sure Amsoil does too.
1986F150six
Aug 24, 2017 09:22 AM
WilleyJoe.62
19
Mar 4, 2014 07:44 PM
tomde2
Jan 25, 2010 12:12 PM
MARC
Jan 16, 2005 03:21 PM
quincyjr
Apr 12, 2004 04:54 PM
