Gonna do a bit of cleaning of the EGR, EBP, MAP this weekend along with changing my tstat. On the EBP is it located right up front on the engine (close to the EGR value) and the Map hose is attached to the pass. side intake--not sure where the MAP sensor is. Are there any other easy things like this i need to look at and clean as well?
The Map is bolted on the heater core box with 3 nuts black plate I don't clean the map it self just follow the hose down to the Intake I un hook the hose at the sensor and use it to help unthread the threaded nipple that's where it will be clogged I think a 10 mil wrench to loosen it.
