Map sensor issue...
Old Oct 24, 2008 | 03:44 PM
Action4478's Avatar
Action4478
Map sensor issue...
I thought I would throw this out there & see what sticks ,cause I don't know what is wrong ..
A friend of mine has a 97 7.3 ,started running like a dog..I told him to unplug the map sensor ,,(ran better ) so he replaced it ,,no better ..ran the same as the old one ,he's been running it with it unplugged ...The hose is new ...
At the time I didn't think to check if it was plugged
Scanned the truck & buzzed it , the only thing that I thought was odd ,was the IPR DC% was 9 (ICP was seemingly ok at 580)
Contribution points to 6& 7, but it runs & idles just fine ,,
MAP is the only issue ,,
Any thoughts ?...
RED
Old Oct 24, 2008 | 04:00 PM
Hussler's Avatar
Hussler
Shot in the dark .. where the MAP hose connects to the passenger manifold make sure the fitting the hose connects to is not plugged. Just stick something small in there, drill bit etc.
Old Oct 24, 2008 | 04:25 PM
Action4478's Avatar
Action4478
thanks ,,
Will do ...
Old Oct 25, 2008 | 10:27 AM
MagKarl's Avatar
MagKarl
When I bought my rig it barely ran, needed a ton of stuff fixed. One of the problems was some "mechanic" didn't hook the hoses in the MAP area up correctly. He routed the manifold boost line to the little heater box chamber that you have to remove to get the passenger side VC off. Then the MAP was connected to the hose that should have gone to that heater box, I think that one might be vacuum, can't remember.
weekendwarriorfsw32
Mar 14, 2016 12:29 AM
BradSmith-7.3L
Feb 16, 2016 07:12 PM
Jmanb13
Sep 19, 2015 07:48 PM
KB300
24
Mar 7, 2012 08:58 PM
yeldarb82
13
Sep 16, 2009 06:56 AM
