map sensor?
Old Apr 1, 2008 | 01:36 AM
jimwilsonmasonry's Avatar
jimwilsonmasonry
map sensor?
could you get more performance by honin out the hose on the intake hose of map sensor and the turbo manifold hose a bit and puttin a bit bigger hose on it
Old Apr 1, 2008 | 05:54 AM
Cuda_jim's Avatar
Cuda_jim
Nope, flow is not an issue, that's what porting the MAP sensor hose would accomplish.
IMO smaller would be better....the sensor would react faster to engine demands...but totally un-necessary. Some guys here use a blow-off valve/pressure regulator to stop the PCM from de-fueling under high boost conditions (25-30 psi).
