MAP Sensor location
Oct 24, 2010 | 10:59 AM
MAP Sensor location
did a search and couldn't find out what I needed. Where is the thing located? Going to replace it, keeps on throwing a "no boost detected" code even thought the turbo is working fine. thanks
Oct 24, 2010 | 11:02 AM
passengers side on top of the heater box
Oct 24, 2010 | 11:08 AM
There is a hose that looks like a 1/4" fuel hose leading from the intake spider to it. Make sure that hose has not blown off.
Oct 24, 2010 | 11:33 AM
will check when I get home, thanks
Oct 29, 2010 | 11:28 PM
that was easy, can't believe what the shop wanted for that... reps sent.
Oct 31, 2010 | 10:19 AM
Oct 31, 2010 | 11:22 AM
Now I need to wait for a cold morning to see if the false "no boost detected" codes keep showing up. Does seem to be running better though.
Nov 3, 2010 | 06:56 AM
well, got the code again this morning. would disabling the EBV take care of this issue?
Nov 3, 2010 | 07:45 AM
What is the code number? More info please. It will determine if it is an electrical or mechanical problem setting the code.
Nov 3, 2010 | 10:17 AM
think it was 1248. will look after work today. Code reader @ O'Reilly's says "no Boost detected" Also had 1247. Autozone reader said "fuel/air mix".
Nov 5, 2010 | 10:46 AM
Quote:
Originally Posted by
HD Rider
Hose was good. checked to see if full of carbon, was clear...
F2502011
Jul 4, 2017 01:56 PM
dj lpm
2015 + Expedition & Navigator
Apr 15, 2016 12:31 AM
iduger
Nov 4, 2010 10:53 AM
KRDiesel
Jul 25, 2009 08:31 PM
cajunsf
1978 - 1996 Big Bronco
May 28, 2006 11:44 AM
1997 ,
2000 ,
73 ,
aviator ,
diesel ,
f150 ,
f250 ,
ford ,
location ,
map ,
navigator ,
pickup ,
powerstroke ,
problems ,
sensor
