1997 F250HD up pipes
on
1 Post
It's not an easy job, but you don't have to do all that. Take bolts out of the clamps at the collector on the back of the turbo, then remove the bolts from the clamps at the manifold. Hopefully the donut gaskets will slide on the pipes so you can push them into the collector enough to pull them away from the manifolds and down and out. It takes some swivels and extensions to get at all the bolts, and some wiggling and prying to gat them out, but it can be done. If you have to, you can pull the turbo and make it a little easier to get the pipes out.
on
1 Post
LOL! Yeah, I was gonna let them figure that one out on their own Even a man that doesn't swear will probably mumble a few choice words under his breath LOL! I think I have made up some new cuss words messing with up pipes! LOL! Me personally, and this is just me, I will drop the trans and work on up pipes now before I fight with them. It's worth it to me.
I pulled the turbo and passenger side pipe. I left the driver side pipe connected to the collector and removed that pipe and the collector all in one shot. Re assembly was opposite order. get the swear word dictionary because you WILL be adding to it.
Nick the engine looks great! Thanks again for letting me assemble my pipes on your block.
4x4countryboy
05-11-2012 12:03 AM
Josh88Ford
09-17-2011 07:07 PM
