IH bellowed up-pipe problem?
Old Jun 1, 2010 | 12:55 PM
wolfrace's Avatar
wolfrace
You like apples?
I have my turbo reinstalled with up-pipes connected to the back of the turbo (v clamp), but my drivers side up-pipe to exhaust manifold is off about 1/2 high. I was able to pry the pipe into place to get the bolts in loose.
My question is, will I be ok to suck the upipe down and in, or will this damage my new up-pipes?
Old Jun 1, 2010 | 01:56 PM
TN97STROKE's Avatar
TN97STROKE
When I did mine I left every thing loose till I got every thing connected then tighten everything down. loosen the bolts at the manifolds and then pull every thing tight. Hope this helps.
Old Jun 1, 2010 | 03:20 PM
wolfrace's Avatar
wolfrace
You like apples?
Everthing is loose right now, I am thinking maybe if I torque the turbo down, it may line up? I will have to try it, if not will pulling that pipe down and in 1/2" damage the up-pipe?
Old Jun 1, 2010 | 03:53 PM
bkuuz1's Avatar
bkuuz1
I used a rope to pull the up-pipe down far enough to get the bolts in on the up-pipes. Once you get the up-pipes bolts in tighten the clamp on turbo. Up-pipes will line up when tightening the bolts. Don't forget to use never-siez.
dan.alger
Oct 23, 2011 07:55 PM
2000ca250
26
Jan 1, 2010 11:44 AM
kent's f-350
Oct 27, 2008 09:19 PM
davidson915
Feb 7, 2008 07:34 PM
Kwikkordead
71
Jun 22, 2007 12:29 AM
