up pipes??
Old Apr 15, 2007 | 06:10 AM
ron's power stroke's Avatar
ron's power stroke
up pipes??
ok guy's..my Trans is coming out and being replaced with I hope to be a BTS..I noticed my up pipes have no leaks and seem to be in good shape..but the bolts on the top half are getting weak and smaller in size from heat, rust and age..I want to change the bolts now while its easy to get at with the Trans out...can I just cut the bolts and replace with new with out taking the pipes out and taking off the turbo??or should I get new gaskets as well and take it all apart??like I said the pipes look good and there is no leak right now..also are the bolts threaded into the manifolds?? or are they just a nut and bolt?? they don't look like they will come out that easy..what's the best way to get them out with out breaking the manifolds?
thanks a lot guy's
Old Apr 15, 2007 | 07:10 AM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Doughnut gaskets could be ok for now, may start leaking soon. If it was me, I'd replace the gaskets while everything is easy to get to. Mine are leaking, have the gaskets onhand, just waiting on it to warm up around here. The rusty bolts I plan on cutting and replacing, don't want to break anything removing them.
Old Apr 15, 2007 | 07:19 AM
Uzumati's Avatar
Uzumati
Ron, Kwikk had the best method for removing the bolts. Soak the down in PB Blast and whe you go to remove them dont try to back the out all at once, back em out a little then take the back down and spray, back em out a little more, ect. All should be Nut and Bolt.
Old Apr 15, 2007 | 07:25 AM
ron's power stroke
thanks guy's..if i do the gaskets too will i need to remove the turbo? or can that stay in place??? with getting the BTS trans cash flow will be short..if i remove the turbo that means new o--rings and what ever..as of right now nothing leaks..hate to fix what isnt broke...
Old Apr 15, 2007 | 07:38 AM
Uzumati's Avatar
Uzumati
There is the collector between the ups and the turbo held to the turbo by one of those *&%$#$^%@&)@*&*#^%#%^& marmon clamps so you shouldn't need to touch the turbo at all unless you see a little dampness when you get up behind it. May be a good thing to have on hand just in case though.
Old Apr 15, 2007 | 07:40 AM
ron's power stroke
thanks alot Alan....as always your a big help...
Old Apr 15, 2007 | 08:08 AM
Hiflyer746's Avatar
Hiflyer746
manifold
I would recommend having that up pipe manifold that connects the up pipes to the turbo on hand. Three our of four of my broke off. I tried everything to get them out, I wrecked two bold extractors and used a lot of torch gas
TIm
Old Apr 15, 2007 | 10:26 AM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
Ron this is not a bad job if you removing the trand, i had to do it with everything in it, and its a finger busting job, if you want i have that piece where up pipes go in, since i have diferent turbo, i can send it to you, but after you done ill need it back, just if you want to have an insurence while you doing the job, and dont want to wait , in case you brake bolts off,
let me know,
Old Apr 15, 2007 | 12:18 PM
ron's power stroke
let me know,
wow thanks alot pete..ill get under it and see how bad it looks...also gave you rep ponts.
Old Apr 15, 2007 | 12:23 PM
PETE'S_6.0PSD
thanks Ron, just helping out fellow Stroker,,
i have to say one thing, this place brings the best in many people,
let me know wat you need, i have uppipes too in good shape,
good luck under the truck
Old Apr 17, 2007 | 05:51 PM
PETE'S_6.0PSD
Ron here is the link for a injectors, as we spoke
http://diy-injectors.com/
PMS kicking in i see
and let me know if you need anything
Old Apr 17, 2007 | 05:58 PM
ron's power stroke
thanks alot pete...ill check it out..yes PMS..does it ever end ???lol
Old Apr 17, 2007 | 06:01 PM
PETE'S_6.0PSD
never, and whats bad it only gets worst with time,
but im learning to live with it, its like cancer, if you dont spend some money on it it grows out of control,
Old Apr 20, 2007 | 08:58 PM
PETE'S_6.0PSD
Ron anything with the truck? any updates?
did you get it done or planning to do it over the weekend?
Old Apr 20, 2007 | 08:59 PM
PETE'S_6.0PSD
