Rear diff cover
The following users liked this post:
Your post (from all these years ago) helped recently guide me in the right direction. It's actually 5/16x18. I went on a wild goose chase for 5/16x20 and it basically does not exist. But after several phone calls, and much internet research, I discovered it was 5/16x18 (thankfully, as that size is readily available at most hardware stores.)
5/16x18x1 was the perfect size for the thicker aftermarket cover mounting flange. The little 8mm wave lock washers were perfect fit as they were snug on the bolt and small enough diameter to fit inside the recessed holes on the new cover.
1993 F250 Sterling 10.25 rear.
This was the 3/8" hardware provided by the seller, next to the OE Ford 5/16" bolt.
