cab mount sleeves...
i'm currently rebuilding my 1981 f150. it's had tons of things changed on it. a couple years ago, the motor died and it has been sitting collecting rust ever since. i started taking the interior apart to asses the amount of repairs and the cab was not worth even attempting to fix, so i got another cab. when i went after the cab mount bolts, almost nothing was left of them... one i hit with a hammer and it broke off. the rubber bushings were junk as were the sleeves and i have to rebuild/replace 4 out of the 6 cab mounts. does anyone have any specs on the cab mount sleeves as i'm pretty much out of money and need to replace them
"buy" is something i can't afford at this point lmao
all i'm needing are some measurements and i can make them as i have access to just about any size pipe and washers/fasteners. being a welder also helps a lot. i got the cab with complete front clip for $350 and the bushings for $100(cheap for my area) and still have to buy all the steel to build a new flatbed and will be over what i can afford already... actually, i'm already over what i can afford lol
i'm also going to start a thread with pics for my rebuild process
i've called several places and all i can come up with is broncograveyard.com in Michigan to even find part of what i need. i have a new set of cab bushings from energy suspension and i think i'm going to just have to guess for a measurement and just go with washers and a piece of pipe and hope for the best
I would think the length of the sleeve would be the height of the upper and lower urethane bushings together less a little bit for crush.
Peteg5
23
03-14-2011 10:07 AM
nkapphahn
04-07-2009 11:20 AM
