Removing Original Cab Mounts
Old Apr 4, 2009 | 04:00 PM
nkapphahn's Avatar
nkapphahn
ANy trick to removing original cab mounts without cutting or drilling. If they do have to be cut out where can new hareware be found - LMC might be the only option I guess. Thanks
Old Apr 4, 2009 | 04:11 PM
Holiver31's Avatar
Holiver31
lmc isnt the only option,,you have dennis carpenter and macs,,maybe even bronco graveyard,,lmc products can be low grade,,while most of their products are fine alot of them are jap made low grade replacements
Old Apr 4, 2009 | 04:12 PM
73FOMO's Avatar
73FOMO
Are you are talking about the cab mount bushings, or the front metal mounts that are spot welded to the cab itself? If you are talking about the cab mount bushings (mounted to the frame) I took another bolt of the same size as the originals, and after removing the cab threaded them back down into the holes and then took a 2lb sledge to it to knock em out. The came out ok with that method.
Old Apr 4, 2009 | 10:29 PM
zr800apvtwin's Avatar
zr800apvtwin
Where can i get the front metal mounts that are spot welded to the cab itself? for a 79 f250?
Old Apr 7, 2009 | 11:20 AM
73FOMO's Avatar
73FOMO
Mac's Auto Parts - Antique Trucks carries....C7TZ-9911214-RM 29.95, and C7TZ-9911215-LM 29.95. You will have to drill out spot welds to remove.
ehughes8
Sep 7, 2012 04:22 PM
Samsn4
Aug 25, 2012 05:57 PM
santi2322
May 21, 2010 04:42 PM
Happyreefer
Jun 27, 2009 11:57 AM
66F100Again
May 21, 2009 09:56 PM
