Looking to do high idle mod.
Old 09-16-2014, 06:34 PM
LivingLarge's Avatar
LivingLarge
LivingLarge is offline
Hey all, I'm looking to do the high idle mod on my 2005 6.0
I've posted here because I've read somewhere that the excursion is different than the truck.( not sure if that's accurate)
Hoping for guidance for dummies, maybe pics etc.
Thanks in advance,
Michael
Old 09-16-2014, 06:46 PM
william_04_x's Avatar
william_04_x
william_04_x is offline
Here you go, Michael.
Old 09-16-2014, 06:53 PM
LivingLarge
Excellent thread, thanks
Old 09-16-2014, 06:59 PM
william_04_x
Originally Posted by LivingLarge
Excellent thread, can you get me the pics, They seam to be missing.
Look further down page 1, to post #6. I had reposted them after original links had been broken.
Old 09-16-2014, 07:02 PM
LivingLarge
Sorry, I just edited my last post.
Old 09-16-2014, 07:18 PM
william_04_x
No biggie. Of course, make sure you tap a fused circuit that's only hot in "Run" to power the dash switch to the PCM input. Driving with the switch on doesn't do any harm. The 12V signal is only an enable command to the PCM, and the high idle event is initiated through software/programming. The PCM has to prove various conditions(speed=0, foot brake=off, trans not in any drive gear, etc) before idle speed is increased. Parking brake has no effect on mine.
Old 09-16-2014, 08:21 PM
Curt's05's Avatar
Curt's05
Curt's05 is offline
Wiser by FTE
That's a great mod! I use it when it's cold, using my inverter or jumping a dead vehicle. Its a well written post makes it easy peasy to do
Old 09-17-2014, 11:24 AM
carbon coupe's Avatar
carbon coupe
carbon coupe is offline
I did some research on doing this mod to my 7.3l. Has anyone done it and which method did you use? Looking for pros and cons. Found the "module" that splices into the accelerator pedal wires but not sold on that yet.
Old 09-17-2014, 11:44 AM
1NiceHarley's Avatar
1NiceHarley
1NiceHarley is offline
I have so extra wire pig tails (foot or so of wire with a pin that will plug into the factory harness) if you need one. Let me know. PM me works best as I don't check the site very often. I have done this mod on our 6.0 Ex and works great!
Old 09-17-2014, 11:45 AM
David7.3's Avatar
David7.3
David7.3 is offline
When I had DP Tuner do my chip I had him put a high idle in the program, I dont need 6 settings, so I got 1 economy, 2 normal, 3 high Idle 1400 RPM's 4 50 HP 5 100HP and 6 150HP. Works awsome I love it, now I have to do the injectors, Smoke's like a coal train on 6, then I will have them reprogram it for me, A little smoke means buisness when you pull up to a cummins with stacks.
Restlesswildman
10-20-2013 10:38 AM
Weld2
05-18-2013 10:50 PM
san antonio
1999 to 2016 Super Duty
02-10-2011 10:26 AM
Krisx125
12-08-2009 11:49 AM
rocky1074
12-06-2009 12:13 PM
Quick Reply: Looking to do high idle mod.
