Variable High Idle Mod
Old May 18, 2013 | 05:51 PM
Weld2's Avatar
Weld2
Hey guys,
I'm looking to do a high idle mod on my truck, but want to add a resistor with a linear taper potentiometer so that I'm able to manually vary the rpm's.
I have the upfitter switches on my truck, and have found instructions for how to wire the resistor and potentiometer in a 6.7L but not on a 6.0L. I can find the regular high idle mod instructions, but no detailed instructions for the 6.0L.
Are there pictures or detailed instructions on how to install the variable high idle with a resistor on 2005-07 6.0L with upfitter's?
Old May 18, 2013 | 08:37 PM
Yahiko's Avatar
Yahiko
You should use the search tool it is your friend.
https://www.ford-trucks.com/forums/4...-switches.html
Read this. The 05 has two ways to do a high idle.
Sean
Old May 18, 2013 | 09:23 PM
Weld2's Avatar
Weld2
I've come across all those. I'm specifically looking for directions on which wires to attach a resistor and a potentiometer to so that I can adjust the idle. I've found instructions and pictures for the 2011 6.7L but not for the 2005-2007 6.0L.
Old May 18, 2013 | 10:50 PM
Yahiko's Avatar
Yahiko
Read the post I linked to and look for High Idle
The one you want to look at is the PTO RPM speed resistor.
Sean
CornTruckDriver
6.7L Power Stroke Diesel
Feb 16, 2013 01:36 PM
powerstroker100
Apr 26, 2010 10:01 AM
Krisx125
Dec 8, 2009 11:49 AM
sneak
6.4L Power Stroke Diesel
Jan 14, 2008 03:12 PM
