High Idle Mod
Old Nov 20, 2009 | 10:56 AM
rocky1074's Avatar
rocky1074
High Idle Mod
<style></style>I looking to do an high idle mod on my 03 F-350. Can anyone let me know how to go about doing this modification. Thanks
Old Nov 20, 2009 | 11:08 AM
loejukan's Avatar
loejukan
just do a quick search on this 6L forum using "high idle mod" and you will find lots of help on what to do.
Old Nov 20, 2009 | 11:59 AM
Cowboy65's Avatar
Cowboy65
Check-out this link:
High Idle Mod
Old Nov 20, 2009 | 05:18 PM
rocky1074's Avatar
rocky1074
Ok Thanks guys...I did a search on the 6.0 forum, found alot of information and the link the cowboy65 sent helped out alot...Thanks Again
Old Dec 6, 2009 | 10:07 AM
bkvanbek's Avatar
bkvanbek
What are the other ways of doing this mod? I saw mention of it on other threads, but the mentions skipped the basics.
Old Dec 6, 2009 | 10:37 AM
Zmann's Avatar
Zmann
do a search you have 2 idle options ,, one goes by batt voltage the other is set at around 1200 ,, if you don't have up fitter switches you can add them for 100$ or use a toggle .. there is also some directions on using a potentiometer to manually adjust the high idle
Old Dec 6, 2009 | 10:46 AM
bkvanbek's Avatar
bkvanbek
i have searched, but it is confusing. I have a 2003. What option is better? Do I have to put the e-brake on each time? Do I need a switch? The PTO mod I found, how is the other one done?
Old Dec 6, 2009 | 10:57 AM
Zmann's Avatar
Zmann
I did the pto and the e brake does need to be on ,, not sure if there is a work around for that? any toggle switch will work if you don't have upfitter switches ,,
the other option just uses a dif wire and ,, I may be wrong but have heard you don't need the ebrake on for that one??
Old Dec 6, 2009 | 11:03 AM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
I'm pretty sure the e brake has to be on regardless of which wire you use. Good safety feature IMO.
Old Dec 6, 2009 | 11:26 AM
bkvanbek's Avatar
bkvanbek
What difference is there with the other wire? Upfitter switches what are those? and are they on 2003?
There is too many safety features. Besides I am more likely to forget the e-brake is on.
Old Dec 6, 2009 | 11:41 AM
Zmann's Avatar
Zmann
upfitter switches are an optional bank of 4 switches that you can use as you please ,,
My moto if you set an e brake SET IT! then you won't forget it's on
did u see this one yet? https://www.ford-trucks.com/lc/lc.ph..._idle_mod.html
Old Dec 6, 2009 | 11:49 AM
rocky1074's Avatar
rocky1074
I just did mine using the 322 wire & 294 wire with a toggle switch. No E Brake Required. Workes Great!!
High Idle Mod
Old Dec 6, 2009 | 12:05 PM
bkvanbek's Avatar
bkvanbek
I just did mine too, helps with the coolant flush I am doing today. No E-Brake required, must be because 2003.
Old Dec 6, 2009 | 12:13 PM
rocky1074's Avatar
rocky1074
Yea I did mine last week and also did a coolant flush. Worked out great
351Cleveland C4
The Next Generation
23
Sep 23, 2013 06:00 PM
RANGER589
18
Jun 3, 2011 10:03 AM
Smokey1961
Jan 17, 2009 04:05 PM
PowerStrokeHD
Dec 18, 2007 08:31 PM
04SilverSCFX4
2004 - 2008 F150
May 29, 2005 10:24 PM
