I have some scratches on my windshield. I have not seen a glass polishing kit, but years ago I read about using toothpaste to clean up scratches. Haven't tried it yet though.
#0000 steel wool will clean up anything that can be removed successfully. If you can feel a scratch with your fingernail, polishing won't bring it out.
Be careful if you try to use a buffing wheel. The heat can separate the laminate or crack the glass. Not too bad on a flat windshield but if you have curved gla$$
The steel wool didn't do much nor did polishing compound. Had limited success with mild acid and 1000 grit sand paper. Will need to consider a kit versus replacement glass.
I don't know how much the kit is or how effective it might be on your truck's scratches but new glass is just over $100 and you can get the tinted version for the same price. http://www.lmctruck.com/features/fa/fa9rd.htm
Thanks guys. The windshield is on a 1970 Ranger High Boy I'm working on with my brother. This thing has been cursed from jump - just trying to move it along so we can get to a 36 Ford pickup.
But I do have a new windshield seal I've been meaning to install on the 49. Hmmm...
