Wheels
09-02-2014, 01:50 PM
on
Wheels
Will 1993 3/4 ton 4x4 factory steel wheels fit 1977 3/4 ton 4x4 as far as bolt pattern & hub center hole?
09-02-2014, 02:03 PM
yes, the bolt pattern is the same.
09-02-2014, 02:30 PM
Up to 1998 F-250/350's (not 1999+ Super Duties), and up to 2013 Econolines (vans).
09-02-2014, 03:05 PM
Rich is right on the year/models vans stayed the same 8x6.5 pattern
09-02-2014, 03:11 PM
If I'm not mistaken, late model GM and dodge trucks used this pattern as well. (Not sure if they changed in the last couple years)
09-02-2014, 05:24 PM
^ dodge was 8x6.5 until 2002
09-02-2014, 06:21 PM
In that case it was GM that used it up to 2012
09-02-2014, 07:40 PM
IIRC, that some of the GM wheels might have a smaller hub opening than the Ford or Dodge wheels which could be a problem for a 4wd F-250/79 F-350 with a Dana 44HD or 60 axle hub.
09-02-2014, 08:45 PM
Not just those, most Fords are actually hub centered despite having tapered seat lug nuts. I know GM wheels wouldn't fit over the hubs on my rear D60.
WALFORD'S 56
WTB - Parts & other
10-15-2009 10:08 AM
bobpearson90278
03-23-2007 07:45 PM
2tone73
09-12-2006 04:32 PM
stryder
12-11-2002 06:42 PM
flatliner
09-23-2002 11:54 AM
