My 352 isn't a 352??
Old 08-03-2014, 05:42 PM
tartar_sammich's Avatar
tartar_sammich
tartar_sammich is offline
I'm putting a cam in my 1965 F250 and I was cleaning the tops of the pistons when I saw that they were stamped "40". I measured the bore and it is 4.040 inches. The stroke is still 3.50 inches. What does this make my engine now? I wish my dad would let me take it out and bore and stroke it more to make it a 390, but he won't
Old 08-03-2014, 06:25 PM
1972RedNeck's Avatar
1972RedNeck
1972RedNeck is offline
You only have to stroke it to get a 390.
To figure out displacement, it just takes simple math.
Take the radius of the bore, square it and multiply it by pi (~3.14). Take the product and multiply it by the stroke and then the number of cylinders.
Old 08-03-2014, 06:29 PM
SuperSabre's Avatar
SuperSabre
SuperSabre is offline
The factory 360 cubic inch truck engine which came out in 1968 used the 390's bore (4.05) and the 352's stroke (3.50). So your engine is just under 360 cubic inches.
Old 08-03-2014, 06:55 PM
1972RedNeck
358.93 to be exact. (can't be any more exact due to significant digits)
Old 08-03-2014, 09:17 PM
TxStang2010's Avatar
TxStang2010
TxStang2010 is offline
a .040 overbore is fairly common to find in the older engines . just about every engine I have had reconditioned for Mustangs needed boring to .040 over stock to clean up the taper and out of round in the cylinders .
Old 08-03-2014, 09:39 PM
6t6merc's Avatar
6t6merc
6t6merc is offline
There is nothing wrong with an .040 overbore. It is my belief that the 352 of the era had the same cylinder castings as a 390, 410 but were "underbored". The real problem with the design of your 352 (and mine) is the compression ratio. My solution will be a 428/410 crank and rods and 410 pistons. The CR will be higher but the motor will still be cheaper to run, even on 93 gas. And it will have an extra bunch of juice!
Eric
Old 08-04-2014, 01:47 AM
TBird Larry's Avatar
TBird Larry
TBird Larry is offline
The 300 horse 390's from the factory had 10.1:1 compression and they loved 100+ leaded fuel. Others had up to 11:1. and you could pump them up to 13:1 with domed pistons.
Can't you bore them 80+ over and still have some meat left? There is all kind of ways to build an FE.
Old 08-04-2014, 05:05 AM
jowilker's Avatar
jowilker
jowilker is offline
I agree the 40 is not a Ford number but rather a over bore size.
John
Old 08-09-2014, 10:31 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
352: 4.00" bore, 3.50" stroke.
360: 4.05" bore, 3.50" stroke.
390: 4.05" bore, 3.78" stroke.
livalot4
10-26-2007 09:40 AM
65'f1004x4conver
12-07-2006 08:39 PM
61 uni
09-16-2004 06:33 PM
Andysutt
05-06-2003 02:33 PM
reidsean
04-03-2003 06:25 PM
Quick Reply: My 352 isn't a 352??
