Clutch Release Assembly Problems
Old Aug 8, 2014 | 09:59 AM
bjones10919's Avatar
bjones10919
I have a 1965 F100 Short Bed. The clutch release asembly is worn out. I have purchased new bushings and stuff from LMC. My problem is...the bracket closest to the engine that the post that the bushin is mounted to has been replaced with a piece of flat plate that has been drilled out. LMC shows this part in their drawing of the clutch release assembly but doesnt carry it. Anyone know where I can get one new or used?
Old Aug 8, 2014 | 04:50 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by bjones10919
I have a 1965 F100 Short Bed. The clutch release assembly is worn out. I have purchased new bushings and stuff from LMC. My problem is...the bracket closest to the engine that the post that the bushin is mounted to has been replaced with a piece of flat plate that has been drilled out. LMC shows this part in their drawing of the clutch release assembly but doesnt carry it. Anyone know where I can get one new or used?
Please, when asking questions, list all the pertinent details.
Pic: 1965 F100/250 2WD: 240/300 I-6 has a stud (C5TZ-7A535-A), while 352 has a bracket (C5TZ-7A572-A).
Which type does your truck have?
Old Aug 8, 2014 | 09:21 PM
bjones10919
Thanks for responding. I need 7A572. Evidently my motor had been changed prior to me purchasing the truck. It now has a 302 in it. Will this part work with that engine? If not do you know of any modification that can be done?
Old Aug 9, 2014 | 10:24 AM
daveengelson's Avatar
daveengelson
I am certain member will add comments if info is incorrect. On my 65 w/ the 302, there's is no bracket, the stud/release pivot ball, is threaded directly into the engine block.
Shortly after purchasing the truck I found the clutch assembly was not aligned and found rather than purchase the correct stud the PO used the 6 cyl. stud and tapped the threads with the engine still in the truck, thus the stud/release pivot ball was off center. When it came time to pull the engine I cleaned up the threads and installed the correct stud/release pivot ball. There should be threads on the side of the block, make sure the thread count on the stud/pivot ball is the same as on the block, 6 cyl. stud has a different size and thread count.
If U get a chance, post pic. Oh, and if I have not taken the opportunity to welcome U to FTE then Welcome!! Looking for your input, and post pic's when you can.
Old Aug 9, 2014 | 10:52 AM
NumberDummy
C8UZ-7A535-A .. Clutch Equalizer Bar Pivot STUD-Engine Side / Obsolete
1969/79 F100 & 1975/79 F150 302 / 1969/74 Econoline 170 I-6 & 302 / 1979 Econoline (E100/150) 302 (302 not available in 1975/78 Econolines).
WESLEY OBSOLETE PARTS in Liberty KY has 4 = 606-787-5293.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 131 = 800-476-9653.
6978sghfbjklgdfsjhkl
Dec 15, 2013 10:59 AM
seneca87
Sep 17, 2011 11:44 PM
White97
13
Dec 7, 2008 06:47 PM
Scifi266
May 21, 2007 12:26 PM
thatdude
Dec 15, 2003 03:08 PM
