Please help Id my FE
Old Sep 15, 2004 | 07:46 PM
61 uni's Avatar
61 uni
The moter is completly apart. I cam measure anything. The pistons are stamped 390 but the tag on the intake said 360. Can I determine the engine size by measuring the pistons, rods, ect? The crank has no numbers on it so I can't run the numbers.
Old Sep 15, 2004 | 08:34 PM
gtex's Avatar
gtex
The crank should have some ID numbers on it!
The stroke is the only real way to determine the displacemt of an FE. And that's actually easier with the rotating assembly installed. You might be able to look at and measure the stroke on the cylinder wall...maybe theres a clear ridge at the top and some indication at the bottom of the cylinder of the bottom of the stroke.
The rods should have a part number as well, which might help determine if they were 360 or 390 rods. I assume by the pistons being marked 390, that they are the standard 4.05" bore, but you could measure that as well. Usually they are marked with an overbore if that was done...
Old Sep 15, 2004 | 08:41 PM
carras's Avatar
carras
According to How to Rebuild Big Bllock Ford Engine by Steve Christ
Bore is
4.00" on the 332 & 352
4.05" on the 360, 361, 390. 391 & 410
4.13" on the 406 & 428
4.23: on the 427
Stroke is
3.30" on the 330 & 332
3.50" on the 352, 360, 361
3.784" on the 390, 406 & 427
3.79" on the 391
3.948" on the 410
3.984" on the 428
Old Sep 15, 2004 | 08:49 PM
61 uni's Avatar
61 uni
How can I measure the stroke? Or can I since the engine is apart?
Old Sep 16, 2004 | 12:13 AM
FERacing66's Avatar
FERacing66
itll be hard, but like scouder said, look at the cylinder walls and try to see if you can see the where the pistion has been going, then measure the top ridge and bottom ridge and thats your stroke.
Old Sep 16, 2004 | 02:31 AM
BB's Avatar
BB
It's probably a 360, they used car 390 pistons.
Just like the truck 390 used car 410 pistons.
Old Sep 16, 2004 | 08:29 AM
gtex's Avatar
gtex
What, now Scouder and me are they same guy?
You'd think on a running motor there would be some visible sign on the cylinder wall showing the stroke, from the rings.
Old Sep 16, 2004 | 06:33 PM
carras's Avatar
carras
you can put the crnk in temporarily with one psiton&rod to get the measurement
Blakester122
Sep 1, 2015 10:51 AM
RatRodAlex
Aug 21, 2015 08:04 PM
thomgcfour
Dec 7, 2012 06:20 PM
AnOldDog
Dec 16, 2005 09:22 PM
stingerstang
Sep 17, 2004 04:10 PM
