c6 shifter arm question
so the c6 that came with my truck has the linkage set up for a floor shifter, the lever on the trans points up. can I just remove the linkage and install it with the arm pointing down so it will work with the column shifter, or do I need a column shift arm for the trans?
The arm and shaft that it's attached to are a one piece assembly and can't be taken apart.
To change the arm you have to drop the valve body. It's not too bad and, once the transmission is drained an the pan removed takes about a half hour, laying on your back.
The hardest part of the deal is getting the trans arm and the kickdown arm to reengage the valve body because it's above the valve body and you have to do it by feel.
The last picture is the shift arm you should have.
thanks. I know it's one piece and how to remove / install it, just need to know if I could flip it or if the floor and column shift apps used a different piece.
btw, I've been following your rebuild/resto thread, awesome work! I hope mine looks half as good when it's done.
Yeah, it's a different part. Part number D8TZ-7A256-A
EDIT: Corrected wrong part number
The following users liked this post:
bighaus75
09-24-2011 02:11 PM
mlf72f250
01-18-2004 07:42 PM
teschwab
09-03-2002 11:49 AM
