Torqshift issue V10 Mike please help
Mike I am hoping you could chime in and give me some ideas whats wrong.
I have had your tune on my 2005 V10 extended two wheel drive van for 4 years and been very happy. 130,000 several fluid changes and external filter changes, fluid is good and full.
It has started revving up between 2nd-3rd gear changes, not a lot but it doesn't snap into gear like it did before and its slow to engage that 3rd gear.
My reverse has been slow to engage for about a year now.
Apart from that it works fine.
I went from the 89 tow to 87 tow just to see if there was a difference, no difference. I went back to the 89 tow and its the same.
Do I need to disconnect the battery on the vehicle to reset anything.
Any help much appreciated
Andrew.
Andrew.
Just Google 5R110 performance solenoid. I got mine off eBay for $139. But you'll find them on a lot of performance sites. It's an fairly easy install that only requires removing the pan to get to. There's also a few nice threads with pictures over on the powerstroke forum on how to install it.
http://www.rudysdiesel.com/_e/Transmission_Upgrades/product/DCSolenoid/Modified_Direct_Clutch_Solenoid_Ford_Powerstroke_5 R110.htm
I replaced the solenoids for intermediate and low/reverse today and no change. Went to Ford and they updated the ECU no change, checked the electrical and nothing showed up. They say its hydraulic/mechanical and I need a rebuild.
The only thing I cannot make sense of is that in D the 2-3 shift flares up engine rpm and then engages. In tow/haul it shifts 2-3 perfectly and then flares the same way for the 3-4th gear change. If its internal hydraulic/mechanical, why does it shift fine 2-3 in tow mode? I don't understand that. AE
Replaced the tranny. Ford certified 100k warranty with a couple of sensors and tax $3500. It now shifts like normal, I am going to leave it stock for a while and see if I can live with the tow/haul mode. I don't like not being able to lock it in 4th gear, but will give the updated program a try that ford put on it. thanks for the help
AE
AE
andrewzx92000
07-23-2014 09:42 AM
andrewzx92000
06-08-2011 01:31 AM
rnelson664
1999 to 2016 Super Duty
02-15-2007 02:40 PM
