E4od transmission going fast in reverse
Old 07-01-2014, 04:08 PM
Mr. Electrician's Avatar
Mr. Electrician
Mr. Electrician is offline
I have a 97 250 diesel with a rebuilt e40d transmission . The trans came out of a 97 parts truck I own .It work great in the parts truck. I put the trans in my truck and it start pulling fast in reverse when it gets warm. When it is first crank it works great but when truck heats up the trans go fast. When you put the truck in reverse it stars out right then starts pulling faster. It has new fluid & filter and is a very clean trans on the inside. It works great in forward gears and shifts great. It pulls strong and smooth. Just reverse halls ***. If any you guys out there every seen this are maybe can offer some help I will love some info to maybe solve this problem. Thanks
Old 07-01-2014, 07:49 PM
quesey's Avatar
quesey
quesey is offline
LOL Let off the go pedal
J/K
Never heard of that
Old 07-01-2014, 07:59 PM
Mr. Electrician
Yes, never seen this myself. i got the feeling that the tc is locking in. just hate to take it to the shop.
Old 07-01-2014, 08:21 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
PM Mark!!!
Old 07-01-2014, 08:24 PM
Mr. Electrician
I new to this site. Been reading all day and see he knows so I email him. Hope he gets back to me.
Old 07-01-2014, 10:56 PM
quesey's Avatar
quesey
quesey is offline
May want to check the fluid level then. If it is low it could lock up the converter
Old 07-02-2014, 09:00 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
Low fluid level is the most common reason for this.
Old 07-02-2014, 11:04 AM
Mr. Electrician
The trans is full of a good grade oil. New filter ,and tc oil was change. I'm going to check the wiring harness & solenoid pack. I driving a lot of these fords as work trucks, never had one do this.
Old 07-02-2014, 05:03 PM
Mark Kovalsky
What do you mean by a good grade of oil? It needs to be MERCON or MERCON V.
The next step would be to put a pressure gauge (0-350 PSI) in the test port on the side of the trans. See what line pressure is doing in reverse.
Old 07-02-2014, 05:56 PM
Mr. Electrician
I used MERCON oil no cheap stuff . Ok I will check the pressure . I'm just shock it work great in the truck I took then trans out of. I ran that parts truck around the dirt roads and the farm for hours playing and the trans work fine. Ran up the pave rd at night just to see how it drives at high speed and the trans work great . Just my luck but going to figure it out . Thank you
Got to love them fords.
halaferd
26
04-20-2012 06:28 AM
homesteader
2004 - 2008 F150
12-28-2011 09:42 AM
jas88
18
10-04-2008 04:50 PM
97HD4X4
10-30-2003 01:39 AM
Quick Reply: E4od transmission going fast in reverse
