Rear cab mounts new bushings
Old 06-25-2014, 06:15 PM
dadsgp's Avatar
dadsgp
dadsgp is offline
FYI
I was able to install new polyurethane in my rear cab mounts, the sleeves were good so just needed to replace rubber. I drilled the poly with 11/16 and inserted sleeves then cut to length. Used McMaster Carr for generic materials. If its cut to length first the poly spun and split with drill.
Just an option instead of buying new cast mounts.
Old 06-25-2014, 06:57 PM
old_dan's Avatar
old_dan
old_dan is offline
Sounds like a good idea. Modern materials should be good for the old truck.
Looking at your post count....welcome to the forum! You should give us a little background on your project. Pics are always welcome!
Dan
Old 06-26-2014, 09:19 AM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is offline
Have you got a picture?
Old 06-26-2014, 10:21 AM
dadsgp's Avatar
dadsgp
dadsgp is offline
Pictures of bushings
I have some photos of installing but can't post attachments. I used 9697k118 from McMaster $12.70. I can email if interested.
My project is 1949 F2 on 1998 explorer awd 5.0. Cab is now mounted and new trans hump is molded and ready for fiberglass.
I fought door hinge pins last week. One was easy others had to cut with dremel.
Old 06-26-2014, 10:30 AM
bjmayberry2
If you send them to me I'll post them here for you.
Old 06-26-2014, 10:50 AM
bjmayberry2
Old 06-26-2014, 10:55 AM
dadsgp's Avatar
dadsgp
dadsgp is offline
Thanks bj
I created an album with captions hopefully I will figure this out.
Old 06-26-2014, 12:33 PM
christurney77's Avatar
christurney77
christurney77 is offline
Great idea... reps going your way...
Old 06-26-2014, 04:45 PM
bobbytnm's Avatar
bobbytnm
bobbytnm is offline
Roast em' if you got 'em
Received 3,841 Likes on 1,840 Posts
Nicely done!
Thanks for taking the time to take pictures and share with is.
Here is another alternative;
https://www.ford-trucks.com/forums/1...t-rebuild.html
I used some leaf spring bushing from a late model Dodge truck
Bobby
Old 06-27-2014, 11:23 AM
jonf's Avatar
jonf
jonf is offline
Do we really have to use the arms ?
I know the frame was made to flex, but has anybody just mounted the rear of the cab solid?
Old 06-27-2014, 11:49 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
There is a guy mounting solid on here, but he's not on the road yet. He has stiffened the whole frame too.
I'd kind of worry about poly being a little too stiff; you do want the links to flex. It will be interesting to see how it works out.
Old 06-28-2014, 09:31 AM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
I'd kind of worry about poly being a little too stiff; you do what the links to flex. It will be interesting to see how it works out.
Not that it is a big concern on these trucks but every little bit helps . . . the rubber bushings would isolate the cab from road noise, engine vibration and other NVH sources. The poly would be noticeably worse and mounting solid would be . . . well, pretty noisy.
jackbodom
Paint & Bodywork
12-24-2011 10:21 AM
johnstoys2
08-11-2007 10:48 PM
Orange1975
05-17-2007 10:43 PM
55forder
02-17-2004 02:13 PM
danbo
12-30-2003 09:57 AM
Quick Reply: Rear cab mounts new bushings
