Coolant filters
#92
#93
What filter kit work with a 97? I have looked on e bay and riff raff and they say 99 to 03 I want to just do the spin on. I can build it but would like to just buy a kit. well I have found a few kits but not sure if one is better or not. Ball valves useful? do the charged filters work on the basic kits? it just a spin on...?? Probably cheaper to build on..
#95
https://www.ford-trucks.com/forums/1...l#post16111419
https://www.ford-trucks.com/forums/1...l#post16095736
https://www.ford-trucks.com/forums/1...l#post16101913
#96
#97
I have a 97 with the 7.3 and I got mine here... www.nasautomotive.com Get filters from Napa or Wix and on Ebay. I like it.
Thanks for the info. Just ordered the kit for 83.99 on sale with no tax and free shipping.
I'm a little confused about using the sca charged filters. Some of the threads say that the sca charged filters only add what is needed to maintain the proper sca levels, somehow. But I've also read that they releases a constant amount of sca and that you could end up with and excess amount of additive in the coolant. Do different brands behave differently ?
Thanks again.
Tom
#98
Thanks again.
Tom
Thanks again.
Tom
NEW PENRAY SYNTHETIC MEDIA COOLANT FILTERSPenray
http://www.dieseltechmag.com/2015/02...oolant-filters
#99
[QUOTE=TOMMAY;16134601]Thanks for the info. Just ordered the kit for 83.99 on sale with no tax and free shipping.
Tom/ Quote..
Thanks again.
What I would do its... use this situation to change coolant. Refill with Pre Charge coolant and then use a filter without the charge. Then test the coolant every so of tnen depending on amount of mileage you are putting on. Then add the additive whenever needed. If you are not going to change fluid you should test the coolant to see where you are and add additive as needed. Additive from parts store isn't all that expensive
Tom/ Quote..
Thanks again.
#100
Appreciate the advice.
I had a coolant flush and service with the proper coolant and distilled water when I bought the truck about two years ago. Since then I've driven about twenty thousand miles. I added a little coolant from time to time due to a minor leak after a transmission rebuild where the transmission lines go into the lower part of the radiator. The fittings have since stopped leaking.
I bought a bottle of test strips today and everything tested out perfect, PH 8.0, coolant -34 and 1200 ppm on sca's. Guess I'll not bother with a filter with sca's at this time . The coolant looks nice and clean so I'm gonna run it for a while longer.
I'm up in Kentucky now ant the only test strips they had at the Napa store were in a bottle of fifty with an expiration date of Jan of 17. Guess I could test the sca's every week and still couldn't use them all up. If anybody needs some strips drop me your address and I'll mail you some free of charge when I get back home in a couple of weeks.
Thanks again
Tom
Thanks again
Tom
#101
Thanks again
Tom
Thanks again
Tom
biawokauns
04-27-2009 10:19 PM
