Coolant Filter
Old Oct 3, 2012 | 04:55 PM
Punisher29073's Avatar
Punisher29073
Coolant Filter
I am getting ready to do a coolant flush on my truck. Is there any advantage to adding a coolant filter to these. Trucks? I have seen them for the 6.0s but not the 7.3s. I am assuming there is a reason for that. Any info would be appreciated.
Ryan
Old Oct 3, 2012 | 06:15 PM
Pitcrw6's Avatar
Pitcrw6
The advantage is getting all the silica sand out when they were made. Your water pump will thank you for it. I installed one on both my 7.3's and I couldn't believe the crap that was trapped in the filter. Worth the money IMO.
Old Oct 3, 2012 | 06:26 PM
Punisher29073
Where did you get your kit?
Ryan
Old Oct 3, 2012 | 06:54 PM
Pitcrw6's Avatar
Pitcrw6
Dieselsite.com. I spelt it wrong the first time.
Old Oct 3, 2012 | 07:02 PM
timmyboy76's Avatar
timmyboy76
stole the idea from here...
Welcome to guzzle's Coolant Bypass Filter Mod Web Page
Chased my filter and filter base from here...
filter...Wix 24070 & Napa 4070 Coolant Filter: FleetFilter Secure Online Store
filter base...http://www.fleetfilter.com/filter/wi...ses/24019.html
All fittings and hose from depot and autozone.
Old Oct 3, 2012 | 08:39 PM
Punisher29073
Great. Thanks. I am going to have a fuel filter, coolant filter, 2 oil filters an canister transmission filter. Dayum! I thought the oil changes were expensive before.
How often should I change the coolant filter?
Ryan
Old Oct 3, 2012 | 08:56 PM
Orezona's Avatar
Orezona
The first time: When you see the coolant isn't flowing into the degas bottle anymore. After that, I don't know because it is still flowing good. I first filter plugged in just a few weeks.
Old Oct 3, 2012 | 09:12 PM
Punisher29073
Ahhh. I will have to keep a close eye on that. Thanks for the heads up.
Ryan
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Having gone through 2 water pumps already, I would say get the filter. There are many reasons to get it and only one reason not to; laziness.
Old Oct 3, 2012 | 09:35 PM
srteach's Avatar
srteach
Put a filter on my truck using guzzles' directions, replaced the pump, and changed coolant (not ELC). Plugged the first filter in a week, the second a month later, been using the third for about 4 months so far. Just keep an eye on the flow into the degas bottle. When the flow stops (or nearly), change the filter.
My coolant went from rust colored to deep green with the first two filters. Well worth it for my piece of mind (and probably saved the new pump).
Old Oct 3, 2012 | 10:30 PM
KelVarnson's Avatar
KelVarnson
Originally Posted by timmyboy76
Doing that same setup this weekend! Also doing heater core cutoff at the same time.
To the OP, note that some filters include the coolant additive in them (24071, for example). 24070 does not, that's the route I'm going.
I don't think you need a kit, you can get all of the stuff individually pretty easily.
OK, that's two more of ya saying that you can see the coolant going into the bottle. Are you using the Guzzle setup, with the "T" in the 3/8" line going to the degas bottle?
The reason I ask is, I was wondering if I DO use the T, will the coolant flow UP to the bottle, or does it just flow down to the radiator? I was wondering if I need to put in a separate feed to the bottle in order to be able to see it flow.
Thanks.
Old Oct 3, 2012 | 11:24 PM
timmyboy76's Avatar
timmyboy76
you'll see the flow Kel. I cut mine at the bend, and installed the T
Old Oct 3, 2012 | 11:32 PM
KelVarnson's Avatar
KelVarnson
Good to know, thank you!
Old Oct 4, 2012 | 10:02 AM
timmyboy76's Avatar
timmyboy76
Kel, nows a good time as well, if not acquired yet, but to install the "wrap around" top radiator hose.
Old Oct 4, 2012 | 10:45 AM
KelVarnson's Avatar
KelVarnson
Yep, thanks, I did that a while ago. Why they EVER thought going through the belt was a good idea, I don't know. I'm guessing that plan was motivated by an accountant somewhere.
