what is the piece called on inside of door?
Old 06-16-2014, 12:48 AM
MONAVIERONJON's Avatar
MONAVIERONJON
MONAVIERONJON is offline
on the xl interior side of each door panel, this is a solid piece of plastic on the forward side of the armrest about where the respective hand would rest. If it had power windows or mirriors there would be rectangular holes for the switches. I'm trying to find a pair and consider this to be a bezel?
Old 06-16-2014, 06:01 AM
Walleye Hunter's Avatar
Walleye Hunter
Walleye Hunter is offline
A picture of it might help identifying it.
Old 06-16-2014, 10:02 AM
F250_'s Avatar
F250_
F250_ is offline
If I understand your description accurately, it is actually called a cover assembly, and is part of the armrest on the door panel. The link below gives you a diagram and the parts called out per the diagram numbering sequence. The actual diagram is also shown below. The cover plate is #5, and the arm rest is #4. If I have not correctly understand the part you are looking for, perhaps the diagram will show you what you need.
The diagram linked below is for a 2000 Superduty with the 7.3, XL trim level.
2000 FORD F-250 Super Duty Parts - AutoNation Ford White Bear Lake Parts (previously Tousley Ford Parts)
#1 Belt w/ strip
#2 Door trim panel
#3 Mirror cover
#4 Armrest
#5 Cover assy
#6 Reflector
#7 Insulator
Old 06-16-2014, 03:55 PM
MONAVIERONJON
that's it, thanks for the assistance, i sure do appreciate it, ROnjon
Old 06-16-2014, 05:17 PM
F250_'s Avatar
F250_
F250_ is offline
You're welcome. Glad to help.
RVXLT
1983 - 2012 Ranger & B-Series
12-13-2009 02:38 PM
mrwolf
Paint & Bodywork
02-13-2008 06:05 PM
tommytorino
1997 - 2003 F150
09-26-2007 04:38 PM
Fair 96
1997 - 2003 F150
05-04-2006 06:44 PM
lorysue
1997 - 2003 F150
11-10-2002 04:23 PM
Quick Reply: what is the piece called on inside of door?
