with the 110 ip is was still making 14psi of boost, I found this when I was almost done with putting a stock ip back in because I thought the 110 was too much for the banks turbo
If you're talking about the gasket that sits at the intake opening, it is item 57, part number 93153. I know it's still available because I bought one a few months ago.
I've had great luck using a square cut Viton oring from McMaster-Carr. Works much better and is oil resistant. If memory serves I got one 3/16" thick to take up any irregularities in the intake and compress a little for a tight seal. No boost leaks on my setup at all at 12-15 psi.
