79 F250 400M won't start
So I've been lurking around here for awhile but this problem really has me stumped.
My 79 F250 400M won't start at all now. Originally started out not starting when hot. So I replaced the ignition control module. Wouldn't start hot. New coil. Still wouldn't start hot. Would run for about 15 min and then shut off like somebody turned the key off. Let it sit for awhile (30 min to 2 hrs) and it'd fire up. Got it home and went to replacing plugs and wires (was due anyway) and since it died from getting it home it won't start at all. Cranks and cranks and cranks. There is power (6+ volts) to the coil with key on. Don't have a volt meter to get an exact number. There's no spark coming outta the coil (new or old. Hooked both up to try). Put a new distributor in. Still cranks and cranks and cranks. I'm stumped now and not sure what my next step is. Any help is appreciated.
Thanks, that sounds good (sometimes folks report no spark when in fact they didn't leave the key on first). Sounds like you're on the right track.
Next I would borrow or pick up a cheap multimeter and double check the coil voltage with the key in RUN to make sure the module can actually ground the coil. If that checks out, move on to check the pickup coil resistance.
